What causes my coil pack to crack. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2012, 06:00 AM   #1
markmann1
Fan#: 106315
What I Drive: 2000 SE Black
FF Reputation: 1 markmann1 Good Standing Member
What causes my coil pack to crack. I have a 2000 Focus with a DOHC engine. I have new plugs, wires, alternator and battery. I have also changed the coil pack mount. The car runs for a short time then boom the coil pack cracked and car dies. This has happened 4 times.
markmann1 is offline
Old 11-16-2012, 09:39 AM   #2
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
Points 2,624, Level 31
Points: 2,624, Level: 31 Points: 2,624, Level: 31 Points: 2,624, Level: 31
Level Up 16% Completed
I'm pretty sure the cracking is actually the spark going to ground through the coil pack body, for this to happen there'd have to be really high resistance somewhere in the wires or plugs, or your wire routing is not right. To begin with I'd ohm the plug wires and make sure none of them are open, resistance will be in thousands of ohms but probably shouldn't be higher than 5K or so given the length of the wires. I have Bosch wires and they were all at 2500 or so when new.
Did this happen once and then you replaced the wires and plugs and it keeps happening to brand new coil packs?
EDIT: One other thing to check is all the wiring going to the coil pack, these wires are known to break and cause problems, so give that a good visual inspection.
6SPD_soul is offline
Old 11-16-2012, 10:49 AM   #3
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,790, Level 54
Points: 6,790, Level: 54 Points: 6,790, Level: 54 Points: 6,790, Level: 54
Level Up 20% Completed
Forum Activity 53%
Buy-Sell-Trade Rating: (23)
^This
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 11-16-2012, 04:56 PM   #4
markmann1
Fan#: 106315
All brand new Bosh wires, plugs. yes it happens to brand new coil pack. Brand new alternater and die hard battery.
Old 11-19-2012, 04:19 AM   #5
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Are you using $15 Amazon coils that have uneven bottoms to crack when tightened down? Try also not tightening so much, they really don't have to be that tight. Plastic, you know. People around here love to crack the stat housings too, again, plastic.
Why did you change the coil mount? If not dead flat the out of plane (say one corner high or low) will crack coil when tightened down.
The longterm cracking on these that normally occurs after long periods of time is from temperature.
amc49 is offline
Old 11-19-2012, 05:16 AM   #6
markmann1
Fan#: 106315
All new Two Ford Motocraft coil packs, Two Autozone Durolast. Got to be a short in the wireing or some thing else. Hopens with in 5 miles on test drive.
