Old 11-14-2012, 01:36 PM   #11
cobie56
Fan#: 84403
What I Drive: '01 ZX3, '07 Civic '12 SEL
My computer and I are in a constant struggle to determine which spells the best. I believe I typed "reflash", but (and you know how uppity Apple products can be), it decided it knew better. In this case, I win.
Although, maybe it knows something I don't, like redraft = redo work done on a drafting table, or a redesign. Hmm, maybe...
ha ha.. thanks.. makes much more sense.. yea, my ios products do the same thing... grrr.. i just turn that feature off...
cobie56 is offline
Old 11-15-2012, 02:42 PM   #12
FordCustomerService
FordCustomerService's Avatar
There have been reports of people being almost stranded because the software controlling the DCT gets confused. Usually, a redraft seems to cure the issue. Of course, there are many stories about bad DCT behavior, but these are annoying rather than debilitating.
The good news is that the DCT itself should be as reliable as a typical manual gearbox, provided the clutch behaves. It doesn't have a torque converter to heat up the fluid, so none of the worries that attach to that in mountain or city driving. The clutch itself is a different issue: hard to say how long they will last.
Hi dan50,
Thanks for the good info. I just wanted to chime in here and make sure everyone knows that the clutch assembly on the DCT is a covered part under many of the ESP plans. You can always give the ESP Sales Service Center a call at 1-800-367-3377 to get details.
Thanks everyone,
Crystal
Old 11-15-2012, 07:40 PM   #13
Kaaru
Kaaru's Avatar
Fan#: 96763
Originally Posted by Vrod21 View Post
I know we have all had issues with the transmission jerking/shuddering sucking in general, but has anyone's actually broke and left them stranded?
I have heard and experienced several stories about the issues with the DCT but I want to know if its going to blow up in some catastrophic highway incident? Or is this thing going to last forever and just feel and act horrible?
Just curious?
I had one tranny failure that occured while engaging in a busy intersection back in March 2012. That was the only tranny failure I had and the only way I had to move the damn thing out of the way was to switch from N to D to limp out of the way. Got back home, parked the car and brought it in at the shop the next morning.
Tranny worked fine going to the shop, dealer told me the car produced an error code, they reflashed the DCT software. Beside the bad DCT behavior, no other tranny errors occured since then.
2012 Oxford White SEL Sedan
Kaaru is offline
Old 11-15-2012, 08:04 PM   #14
Vrod21
Vrod21's Avatar
Fan#: 86456
What I Drive: 2012 Tuxedo black metallic SE
FF Reputation: 1 Vrod21 Good Standing Member
Hmm... Thanks for the info guys. Im still curious to how these transmissions will do in the long run...
Vrod21 is offline
Old 11-15-2012, 09:39 PM   #15
Hodge Podge
Hodge Podge's Avatar
Fan#: 96120
What I Drive: 2012 5-Dr Se Sport Pkg Ingot Silver
FF Reputation: 1 Hodge Podge Good Standing Member
Couple of thoughts...
1. The clutches should last about 150,000 miles, depending on usage. Ford published it somewhere, but you'd have to do a little searching. It's based on a statiscal approach, something like Ford expects at least 70% of will make at least that many miles (which accounts for the track users vs the grannies, etc...) Don't quote me on the percentage though...
2. A few folks threads and various searches have found the grinding/chattering is due to an oil seal leaking the tranny fluid (yes, it has tranny fluid) onto the clutches. Rumor is if the fluid leaks enough to show up outside the bellhousing, it's an easy warranty claim.
____________________
Hodge Podge
2012 Se Ingot Silver 5-Door w/ 201A & Se Sport Package
2001 Silverado 1500 RCLB 4x4 4.8L 5-Speed
Hodge Podge is offline
Old 11-16-2012, 09:16 AM   #16
PratoN
PratoN's Avatar
Fan#: 88058
What I Drive: 2012 Kona Blue Titanium Hatchback
FF Reputation: 6 PratoN Good Standing Member
Maybe I should start parking my car on a hill with the left wheel raised to get more oil to leak... think that'll work?
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at 3.5.1 52k miles and counting...
PratoN is offline
