Does your vent selector stick? Have you broken the cables? Read on, - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-15-2012, 01:35 AM   #1
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Level Up 4% Completed
Forum Activity 13%
So I think I have a solution to this problem. I can't be sure yet, but everything is looking good so far.
But first I want you to answer this question, Do you have a cabin air filter in your car? (if you didn't install it, chances are you don't)
So my blower motor finally died. It had run enough to ware the brushes down to nothing. So I installed a new blower motor.
But first I thought it'd be a good idea to blow the dust out of the vents. Thing is there wasn't much dust that came out. But boy oh boy was there leaves, sticks and other tree debris, all in little bits.
Hmmm.
Seems that leaves and such were chopped up by the blower motor and stuck on the back side of the heater core.
In the process of blowing all this out I rotated the vent selector back and forth. The more junk that cam out, the freer the knob got.
So it seems to me that debris is the main problem as to why things get sticky and break.
Now, I haven't had a cabin air filter in my car ever. That is 11 years. Which time wise seems to fit with others I've seen with similar problems, and no solution has been posted to my knowledge.
To prevent this, I'd say a cabin filter should be used in every car.
To get the junk out you'll have to remove the blower motor. Not difficult, it's only 1 electrical connector and 3 screws. But it's an awkward angle to work at. Stretch before wiggling under the dash so you don't cramp up.
Grab the air hose and blow all the debris out. Change the direction of the vent and blow again. Continue this until you feel you got most everything.
Should be good for another 10 years or so.
Best of luck.
Here is the file on how to remove the blower motor --> http://www.filedropper.com/focusblowermotor
121,000 members and still no sponsored racing.
iminhell is offline
Old 11-15-2012, 01:39 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (11)
This is great info. All focus's can use a cabin air filter it is located under the cowl by the wipers. I think only the first model years actually got the filters installed from the factory. After that I haven't seen a single one with it, but they all have the spot to put them on.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 12-21-2012, 07:13 AM   #3
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
05-07 have no filter- on purpose. An earlier model Foci filter caddy can be substituted in place of the metal mesh screen if you can successfully remove the foam glue holding the screen in place. Something else will have to be used to seal up the filter caddy. Something like automotive window adhesive will work. Adhesive foam rubber should work if it's heavier duty type that will withstand high and low temps. The good thing is that the factory part bolts on the same way so there's no problem with having to drill holes.
Old 01-31-2013, 03:26 PM   #4
nomind
Fan#: 95234
What I Drive: 2000 Primer ZX3
FF Reputation: 3 nomind Good Standing Member
Here is a link for the broken cable fix:
http://www.focusfanatics.com/forum/showthread.php?t=293932
The selector mechanism is by the driver's right knee, and you can try and move it there. I haven't had to dive into the heater core on my Focus yet, so I can't give you any specifics on that.
nomind is offline
Old 03-11-2013, 09:15 AM   #5
fozziebear
Fan#: 111199
What I Drive: 07 Focus SE sedan Deep Torredor Red
FF Reputation: 1 fozziebear Good Standing Member
My 07 has a problem with sticking too.What I found is not in the cables or blower housing but the bled door it self.The rubber seal Ford uses gets sticky over time and doesn't release from the housing where it makes contact.If the center vent and duct is removed you can just get your hand to the top of the blend door and you'll feel it stick.As a short term fix spray some silicone spray on the blend door and work it limit to limit several times.This will last several months then it will need to be done again.
fozziebear is offline
Old 03-20-2013, 07:21 AM   #6
dustin102
dustin102's Avatar
Fan#: 74880
What I Drive: 2007, silver, zx5
Points 617, Level 12
Points: 617, Level: 12 Points: 617, Level: 12 Points: 617, Level: 12
Level Up 34% Completed
FF Reputation: 1 dustin102 Good Standing Member
I have this problem also... And it drives me nuts... Never thought to go in thru the blower housing.... I will try this if the weather ever breaks here! Thanks so much!
Sent from my Galaxy Nexus using FF Mobile
My Focus (My Car)
2011 SE (4 door) with 5 speed manual, 85,000 Miles
Our Focus (Wife's Car)
2015 SE Sedan 5 Speed Manual, 10,000 Miles
dustin102 is offline
Old 06-13-2013, 02:03 PM   #7
roberted5
Fan#: 115674
What I Drive: 2006,Black,LS
FF Reputation: 1 roberted5 Good Standing Member
Great news.
Mine was sticking and the dealer said that a weak spot of Focus.He have me cables but said to expect the same problem.
Is there a link that shows how to take out fan or is it fairly simple?
If your in a pickle and you need air through the correct vents you can remove partial panel under steering wheel and on the side of radio compartment you can move the lever by hand.Down will force air through vents,up through defrost.
roberted5 is offline
Old 06-13-2013, 06:29 PM   #8
Elder
Points 13,378, Level 75
Points: 13,378, Level: 75 Points: 13,378, Level: 75 Points: 13,378, Level: 75
Level Up 32% Completed
Here's one, http://www.focusfanatics.com/forum/s...ht=fan+removal
For an earlier model, and later posts noted some model differences...
Enough general info. to help you out!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-13-2013, 06:35 PM   #9
torradan
torradan's Avatar
Fan#: 25031
What I Drive: 2005 ZX4
Points 2,375, Level 29
Points: 2,375, Level: 29 Points: 2,375, Level: 29 Points: 2,375, Level: 29
FF Reputation: 7 torradan Good Standing Member
I may have to give this a try when I feel like pulling the car apart again. It's having enough problems that I don't even want to look at it and I'm about ready to drive it into Lake Ontario.
Anywho, mine gets stuck on defrost,and I have to reach up inside there and manually move it. As long as I keep it a notch from full defrost, it doesn't stick.
Almost seems like it goes a little further past where it should, and turning the knob isn't enough to rotate it back.
Western New York SCCA - Cone Killer #440
torradan is offline
Old 06-14-2013, 03:36 AM   #10
roberted5
Fan#: 115674
Thanks for the link.My A/C cools better on the passenger side vents than driver side vents including the middle vents,passenger side is cooler.
I don't know what part of A/C is in front of fan.Was any debris or built up around or on it that reduce the A/C's ability to cool?
On cool days my A/C works,probe in dash 42-38 degrees very well but on hot days 58-64 degrees.
