!Massive UNBREAKABLE Lower Motor Mount V1.1 Released!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Massive Speed
Massive Speed Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Massive Speed
Old 09-30-2009, 08:27 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 16,182, Level 81
Points: 16,182, Level: 81 Points: 16,182, Level: 81 Points: 16,182, Level: 81
Level Up 67% Completed
Buy-Sell-Trade Rating: (19)
The Massive UNBREAKABLE has earned its reputation as THE mount to have, and this has made it a wild success for us. Massive has sold a great number of these mounts since their release over 1.5 years ago. To this date, we have not recorded a SINGLE FAILURE.
Not ones to rest on our laurels, we have refined and brought you the even further superior V1.1 UNBREAKABLE mount.
  • Higher 80 durometer custom made Massive Purple Bushings
  • Our High Strength Hardware Kit
Here's what we have to say about these "mighty mounts":
High torque Foci with power adders regularly tear not only the stock/aftermarket bushings, but have been known to shatter the aluminum dogbone itself. While this is undesirable enough, the resulting free motion of the engine can cause damage magnitudes greater such as axle breakage, radiator puncture and shifter cable separation. How do we know? We’ve had it happen too many times… Massive has finally put an end to these woes by offering a truly STRONGER solution. Excessive wheel hop plagues the car in standard form. Not only is this an embarrassing stop light antic, but of course it will seriously impede your ability to smoke that Camaro or Cobalt in the next lane. This also puts incredible shock and abuse on all drive line components and is the leading cause of axle failure. A cast steel alloy mount contains custom Massive spec polyurethane bushings for the best in motion control. Adds some real stiffness to the motor, drastically reducing movement. Expect better shift feel, no more loud banging noise from the stock mount bottoming out on hard shifts, less wheel hop, and more power to the ground! This MSS mount replaces the entire “dog bone” assembly. These mounts also are designed in such a way that the inserts can not come dislodged from the housing.
Massive ALSO includes our complete HIGH STRENGTH HARDWARE kit! Even stock foci have been know to break OE hardware, and with the added stiffness of your new mounts, failure of low grade stuff is inevitable. Often times corrosion will make re-using factory hardware impossible. We selected the highest quality high vis Mil spec blue coated grade 12.9 European hex head cap screws for the ultimate in strength.
Very straight forward installation. If you need assistance, let us know and we’ll walk you through it! Should take less than 1 hour for the average car guy (or girl). Kit comes with instructions. Custom made of high carbon steel for superior durability. Metallic Silver with signature Massive PURPLE bushings. Super high quality construction. Quality made right here in the USA!!!
Just $79!!!
Find em Here!!!
K Dog is offline
Old 05-07-2012, 01:55 PM   #2
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 11,083, Level 69
Points: 11,083, Level: 69 Points: 11,083, Level: 69 Points: 11,083, Level: 69
Level Up 59% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
KDOG
Do you still sell the whole unbreakable mount? I only see the bushings on your website.
SCT PRP FTMFW!
mellephants is offline
Old 05-07-2012, 04:42 PM   #3
focusZX505
FOCUS REVOLUTION
focusZX505's Avatar
Fan#: 19251
What I Drive: 08 Black Coupe 14 fiesta ST
Points 6,234, Level 51
Points: 6,234, Level: 51 Points: 6,234, Level: 51 Points: 6,234, Level: 51
Level Up 43% Completed
FF Reputation: 4 focusZX505 Good Standing Member
How about for the 08+ my bushings are kinda worn
Posted via FF Mobile
focusZX505 is offline
Old 05-07-2012, 05:01 PM   #4
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
No, the steel housing was discontinued by supplier so unfortunately they are no longer avail.
We will have an "EZ-Mount" shortly though, that will have the Massive bushings pre-installed into an aluminum housing, greatly reducing install times. This will be offered in an 00-07 and an 08-11 version.
K Dog is offline
Old 05-07-2012, 05:04 PM   #5
mellephants
Fan#: 52400
Blast! Thanks for the information.
SCT PRP FTMFW!
Old 07-04-2012, 06:33 AM   #6
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,786, Level 54
Points: 6,786, Level: 54 Points: 6,786, Level: 54 Points: 6,786, Level: 54
Level Up 18% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
Buy-Sell-Trade Rating: (23)
I have one and it is beyond night and day.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 07-05-2012, 01:06 PM   #7
atxcontracting
Fan#: 100703
What I Drive: Black, 2002 Focus SE
FF Reputation: 1 atxcontracting Good Standing Member
Do you have these for a 2002 Sedan? How is the vibration? Do you have the other mounts as well? I'm looking to replace all 3, while I'm under there. But its a daily driver and highway car, I'm looking for no vibration.
atxcontracting is offline
Old 07-09-2012, 12:50 PM   #8
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
We offer the lower mount inserts only at this time. If your looking for a DD level of vibrations - you honestly dont want all 3. The lower inserts by themselves will control motion and offer a relatively livable driving experience.
K Dog is offline
Old 11-13-2012, 09:25 PM   #9
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 bbcobra Good Standing Member
would you happen to know if these would fit my VF Engineering lower mount. One of mine has popped out (one side of the smaller bushings). I hope they do, but I don't have a stock dogbone to compare mine to.
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
Old 11-14-2012, 09:54 AM   #10
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Our inserts would not fit the VF housing, no.
We can offer you them already installed into a factory AL housing though, powder coated of course.
Cost is $69.
K Dog is offline
