Crunch sound when going over dips??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-08-2012, 12:03 PM   #1
katkrazy2007
Fan#: 105248
What I Drive: 2008 Ebony Focus SES
FF Reputation: 1 katkrazy2007 Good Standing Member
Unhappy Crunch sound when going over dips???
Well, now that i've solved the other problems, of course a new one occurs!!! Well, there is a dip on my road that I run over when I head to work everyday and when my '08 SES runs over this dip, I hear this odd "crunch" noise and I'm not sure where it is coming from. And it only happens when I am going over this dip and then I don't hear it anymore through my day even when going over other bad parts of roads and bumps. I am scared that this is something serious? Or is it something that isn't a big deal? Could it be the weather changing from being warm to being really cold in the morning? (I live in North MS if that helps if weather is involved)
I hope and pray that this isn't anything serious and that it is a pretty quick and non-dramatic fix. I need input everyone.
<Focus Freak>
katkrazy2007 is offline
Old 11-08-2012, 01:37 PM   #2
mrdeath2000
Fan#: 91996
What I Drive: 2014 White SE 5spd
Points 1,331, Level 20
Points: 1,331, Level: 20 Points: 1,331, Level: 20 Points: 1,331, Level: 20
Level Up 31% Completed
FF Reputation: 3 mrdeath2000 Good Standing Member
maybe the plastic flap under the bumper, like a splash guard? look under there and poke at it with your hand and see what it does.
2014 Focus SE Manual -
2006 Focus ZX4 SE Auto -commuter 110k /traded
mrdeath2000 is offline
Old 11-08-2012, 02:09 PM   #3
FordService
FordService's Avatar
Points 3,388, Level 36
Level Up 26% Completed
Forum Activity 25%
Originally Posted by katkrazy2007 View Post
Well, now that i've solved the other problems, of course a new one occurs!!! Well, there is a dip on my road that I run over when I head to work everyday and when my '08 SES runs over this dip, I hear this odd "crunch" noise and I'm not sure where it is coming from. And it only happens when I am going over this dip and then I don't hear it anymore through my day even when going over other bad parts of roads and bumps...
Hi katkrazy2007,
Have you considered swinging by the dealership so they can take a look? Ford certified techs are your best bet when it comes to diagnosing and repairing your vehicle. Let me know if you have any other questions.
Thanks for the good info, mrdeath2000!
Have a great day!
Crystal
FordService is offline
Old 11-08-2012, 02:15 PM   #4
katkrazy2007
Fan#: 105248
Do you mean in the front or in the back? And if it was the guard, wouldn't it do it all the time, when I drove over other bumps? It only does it on this dip when I'm heading to work early in the morning. After that, no noise while I'm driving any other time and no noise while turning. It made one little crunch sound right exactly after the dip that makes the big sound when I take a left at a four way stop after the dip and then after that, no more noise. I thought maybe it could be some type of bushings? But I will go check the splash guard. If it is that, how could you make it stop?
<Focus Freak>
Old 11-08-2012, 02:26 PM   #5
mrdeath2000
Fan#: 91996
Front. IF it's the splash guard, fixing it depends on what exactly is wrong, may be a simple bolt/push plug has come out, maybe the plastic cracked. Have to see it.
Are driving over this dip in the morning straight on or one tire at a time (like driving over a speed bump and only having one tire go over the bump)?
Before you leave in the morning push on the corners of your car in an effort to cycle the shocks/struts on each corner and see if that changes anything. Maybe it's something thats needing lubrication and sitting over night it settles and that dip in the morning frees it up. Just guessing and throwing crap out there :)
Old 11-10-2012, 01:23 PM   #6
yellowknife SVT
Fan#: 100990
What I Drive: 2002 Black SVT Focus
FF Reputation: 1 yellowknife SVT Good Standing Member
Could be a tie rod. The connection is like a ball and socket. The socket part gets worn and makes a thumping sound when going over bumps. Car can be placed on a lift and then you check for play.
yellowknife SVT is offline
Old 11-10-2012, 06:01 PM   #7
katkrazy2007
Fan#: 105248
mrdeath2000, thanks for that tip! I will definitely check out the splash guard and try the cycling thing tomorrow. I haven't driven her any today so far. I'm thinking its something that is caused by sitting overnight/cold weather. Hoping and praying anyhow. I'm just gonna keep on driving her for a while and not worry about it and we will see what happens!
And to answer about how I drive over it, I am going straight over it without angling my tires at all. Its straight on. I hope this helps!! (:
<Focus Freak>
Old 11-10-2012, 06:03 PM   #8
katkrazy2007
Fan#: 105248
yellowknife, I don't get a thumping sound anymore (that turned out to be my control arm). Its just a scrape sound that I don't get all the time. I run over bumps, speed bumps, railroad tracks, etc and I don't get it throughout the day. I've only heard it twice: both times I was leaving early in the morning when it was cold and hitting that dip straight on.
<Focus Freak>
Old 11-10-2012, 08:50 PM   #9
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Buy-Sell-Trade Rating: (11)
what woild be cool is if you could get your phone out and when you go over the dip have it recorded and see if we all can hear this sound as well
FF MODERATOR
RIFF CREW
ZXthrizzle05 is offline
Old 11-10-2012, 09:45 PM   #10
Tymes
Fan#: 94124
What I Drive: 02 SE SOHC SPI
FF Reputation: 8 Tymes Good Standing Member
try different speeds, we had a really nasty dip near work (they finally fixed it 2 weeks ago, its been there for years) and if I went thru it at anything over 50 km/hr my hard plastic mudflaps on the front wheels would touch down when the struts would compress. It annoyed me so much that I changed the mudflaps to a softer rubber one. Can you tell roughly what part of the car the noise is coming from?
Somewhere there's a DC10 struggling to get off the ground. I'm not a fan of wings on street cars, I like low key spoilers, but not something that you have to custom order from Boeing.
Tymes is offline
