2001 Focus ZTS - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-06-2012, 04:34 PM   #1
hitman2012
Fan#: 105731
What I Drive: 2001 Silver 4dr ZTS
FF Reputation: 1 hitman2012 Good Standing Member
Talking 2001 Focus ZTS
Hey everyone I am new to the ford forums, I just picked up a 2001 focus ZTS 5-speed with 173k on the odometer for 350$. what I was wondering is is there anything I should be looking out for, I have already replaced the ignition coil to an MSD along with the MSD wires and NGK iridium plugs, I also put a bully stage 4 clutch and fly wheel in the clutch and tranny were acting a lil jumpy so I changed it out just to be safe. my next project is the cams, cam gears, header and exaust. This was all new to me as I normally have an import so any help would be great. I live in Florida so I dont have to contend with the weather like I did in New York.
hitman2012 is offline
Old 11-08-2012, 07:18 PM   #2
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
The 2000-2001 Foci were plagued with a number of pattern failures. The ones you will encounter are:
1. Old style ignition lock cylinder failure. This one is only a matter of time. Replace it with new style BEFORE it seizes up and requires drilling.
2. PCV hose collapse at intake manifold. Replace with improved part #XS4Z-6N664-BA
3. Alternator pigtail failure. Solder Motorcraft P/N WPT-118 pigtail kit (1U2Z-14S411-TA) onto wiring harness
4. Front spring failure in the rust states usually near the top. Unfortunately you are over the 10yr extended warranty program on this.
5. Rear spring failure in the rust states usually near the bottom.
6. Rear wheel bearing failure. If you have rear disk brakes, this also requires replacement of the rear spindles. There was a program on this years ago. It's over now.
7. Fuel pump failure. The program on this is now over.
8. Front sway-bar end-link failure - Just replace every 5 years anyhow, they're not hard to replace or expensive.
9. Front passenger-side windshield cowling failure causing water leakage onto front passenger floor pan. Clean windshield and replace cowling.
10. Valve-cover gasket failure causing hot engine oil to leak onto the thermostat housing o-ring in turn causing that to fail. Replace VC gasket with the higher-quality Fel-Pro item.
11. DPFE sensor failure causing DTC P0401 to be set. Replace DPFE sensor with improved-design OEM unit.
12. The usual heat-shield falling off problems, again in the rust states.
13. Ignition coil primary-side pigtail failure
14. IAC valve failure causing hard warm starts.
15. Battery wiring seems to need more than the usual attention to tightness and cleanliness, particularly the grounds.
16. Passenger-side engine mount - fluid leaks out and causes excessive vibration at idle. Replace only with OEM unit.
I've worked my way through these issues over 12 years and my 2001 ZTS is now fairly reliable and fun to drive. It helps A LOT if you don't live in the rust-belt states. By the 2002 MY, Ford had many of these issues worked out.
2001 Amazon Green ZTS 100,000mis
2012 Sterling Grey SE Sedan M/T!
drjkel is offline
Old 11-08-2012, 10:04 PM   #3
hitman2012
Fan#: 105731
Yeah I'm very lucky I don't live in New York anymore, as for pigtails I have to do one on the ignition coil, also I'm doing a vc gasket because I am replacing the spark plugs, wires and ignition coil, I want to upgrade to the svt calipers
Old 11-09-2012, 07:14 PM   #4
hitman2012
Fan#: 105731
shocks and springs I am changing over to coil overs as well, I am also chaning over a for contour valve cover as I can get them in black aluminum
Old 11-20-2012, 04:41 PM   #5
G Ford Fan
Fan#: 80771
What I Drive: 2000 Ford Focus Wagon, SE, Silver.
FF Reputation: 0 G Ford Fan Newbie
Just wanted to say thanks for this list. I printed it out and will keep it with my Haynes manual in my shop. My Grandpa's (now mine 2000 wagon with 45K) runs great and I have not come across some of these issues as of yet.
What is the reccomended mileage interval for changing the key lock cylinder out? What is involved in doing that? Will I have to have the car re-keyed? (hope not, I have 3-4 sets of keys for it now).
Also, how do you diagnose the pig-tail failure for the ignition coil and alternator? Just wondering for the future when the time comes.
Thanks so much, this site and info is GREAT!
-Greg
G Ford Fan is offline
Old 11-27-2012, 11:57 PM   #6
jburkey28
Fan#: 105295
What I Drive: 2009 Cobalt SS/TC
FF Reputation: 1 jburkey28 Good Standing Member
$350?! That's a heck of a deal man..
jburkey28 is offline
Old 11-28-2012, 11:04 AM   #7
Fan4Focus
Fan#: 104234
What I Drive: 2001 White ZX3
Points 126, Level 2
Points: 126, Level: 2 Points: 126, Level: 2 Points: 126, Level: 2
Level Up 52% Completed
FF Reputation: 1 Fan4Focus Good Standing Member
No foolin'. I just bought a 2001 ZTS with 120k for $2000 and I thought I did well!
Fan4Focus
Fan4Focus is offline
Old 11-28-2012, 11:11 AM   #8
Fan4Focus
Fan#: 104234
Points 126, Level 2
Key lock:
"What is the reccomended mileage interval for changing the key lock cylinder out? What is involved in doing that? Will I have to have the car re-keyed? (hope not, I have 3-4 sets of keys for it now)."
I changed mine out at about 110K due to starting to have some issues with it. It is not that difficult to do and I bought a cylinder that came with instructions how to make it work with the original key and the whole process of replacing the cylinder. Takes a little time to figure out the first time but, hey, now I am a lock smith :-) I will try to find a link to send you to where I found mine.
Fan4Focus
Old 11-28-2012, 11:15 AM   #9
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,772, Level 54
Points: 6,772, Level: 54 Points: 6,772, Level: 54 Points: 6,772, Level: 54
Level Up 11% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Originally Posted by Fan4Focus View Post
Key lock:
Kits can be found on the "Bay"
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 11-28-2012, 11:20 AM   #10
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 49%
Key lock:
Hatch Nation #140
freemind is offline
