Shuttering/Bucking, Power Loss Between 3,500 to 5,000 RPM - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-05-2012, 11:12 PM   #1
RevLimit
Fan#: 103978
What I Drive: 2002 Black Focus SVT ZX3
Points 259, Level 5
Points: 259, Level: 5 Points: 259, Level: 5 Points: 259, Level: 5
Level Up 18% Completed
FF Reputation: 2 RevLimit Good Standing Member
Thumbs down Shuttering/Bucking, Power Loss Between 3,500 to 5,000 RPM
I'm having power loss issues between 3,500 to 5,000 RPM. Usually once the RPMs reach 5,000 the car will eventually begin to pull. This only happens when the car is in gear and it's very irritating to have bucking and jerking when I mash the gas until 5,000 RPM when a get a moment of nice power.
I have noticed that in the cold mornings the car RPMs will sometimes jump to 2,000 RPM until the engine gets warm.
It also sounds like sometimes the engine beings to backfire.
So far I have tried the following.
Replaced the fuel filter.
Replaced the spark plugs, gapped correctly.
Replaced spark plug cables.
Replaced the manifold cup-links with the CFM ones.
Replaced fuel pressure regulator vacuum line.
Which is the most likely cause
Air leak behind the MAF sensor?
Failing head-gasket?
Fuel not enough fuel pressure? Although the engine runs strong above 5,000 RPM.
Thanks in advance.
RevLimit is online now
Old 11-05-2012, 11:30 PM   #2
Jaketet
Jaketet's Avatar
Fan#: 104337
What I Drive: 2004 Infra Red SVT 3-door #23
Points 159, Level 3
Points: 159, Level: 3 Points: 159, Level: 3 Points: 159, Level: 3
FF Reputation: 1 Jaketet Good Standing Member
tried cleaning the MAF?
2004 Infra-Red SVT 3-Door
#23 of 1978
Jaketet is offline
Old 11-06-2012, 09:03 AM   #3
RevLimit
Fan#: 103978
Points 259, Level 5
I did not think that the MAF could be cleaned? How can I clean the MAF sensor without damaging it?
Old 11-06-2012, 09:42 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
The best advice I can give is find a local member with a xcal and do a datalog , I will be glad to look it over and help with the problem
Changing parts till you find the issue gets very costly as I am sure your finding out
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 11-06-2012, 09:43 AM   #5
Scout706
Fan#: 105129
What I Drive: 2003 Pitch Black ZX5 AT
Points 38, Level 1
Points: 38, Level: 1 Points: 38, Level: 1 Points: 38, Level: 1
Level Up 76% Completed
FF Reputation: 1 Scout706 Good Standing Member
Very carefully. Seriously, it's usually a thin platinum wire. If you're unsure, maybe a mechanic is the best way to go.
Scout706 is offline
Old 11-06-2012, 10:17 AM   #6
Jaketet
Jaketet's Avatar
Fan#: 104337
Points 159, Level 3
They have MAF cleaner that you spray onto the wire. Also, datalogging like Tom said will give you a better idea of where to start.
#23 of 1978
Jaketet is offline
Old 11-06-2012, 11:47 AM   #7
RevLimit
Fan#: 103978
Points 259, Level 5
I will buy some of the MAF cleaner and give that a try. Do any of you know someone in the Atlanta area that has a dataloger?
Thanks for the feedback everyone!
Old 11-08-2012, 05:44 PM   #8
SVTb4U
Fan#: 88752
What I Drive: 2004 Infrared SVT Euro
FF Reputation: 1 SVTb4U Good Standing Member
I'm in Lilburn/Lawrenceville area
I'd be glad to help with my Xcal.
SVTb4U is offline
Old 05-15-2014, 07:38 PM   #9
RevLimit
Fan#: 103978
Points 259, Level 5
The problems I was experiencing above were caused by a faulty ignition coil pack. I purchased a replacement Ford OEM pack and the car runs great now.
Sorry for not updating everyone sooner.
Old 05-15-2014, 08:35 PM   #10
Elder
Points 13,312, Level 75
Points: 13,312, Level: 75 Points: 13,312, Level: 75 Points: 13,312, Level: 75
Level Up 16% Completed
Tx for posting your cure!
(and nice to see you posting here again)
Had a question just today from a member with the same symptoms, this may help them.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
