2004 svt stock with turbo?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-28-2012, 11:19 AM   #1
svtman123
svtman123's Avatar
Fan#: 105382
What I Drive: 2004 red svt
FF Reputation: 1 svtman123 Good Standing Member
Ok, so I just bought a 2004 focus svt and was wondering something. I talked to a friend of mine about putting a turbo on it. He told me to lower the compression on the engine by rebuilding the bottom end of the motor. Now I did a little research and It seemed to be true for stock engines. But this being a svt engine I was not sure about if it would work without doing all of that, which psi turbo I would be able to get so I will get the most out of the engine and my turbo.
svtman123 is offline
Old 10-28-2012, 11:54 AM   #2
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
you can turbo stock engines, but youll have to limit boost pressure. Some people, who had good compression numbers, got up to 350 whp on stock SVT engines. But these are ragged edge and bad gas will cause deto and engine failure. Personally, 250-300 whp is plenty. GT28rs and done.
BigRed03 is offline
Old 10-28-2012, 04:28 PM   #3
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,738, Level 58
Points: 7,738, Level: 58 Points: 7,738, Level: 58 Points: 7,738, Level: 58
Level Up 94% Completed
Forum Activity 19%
FF Reputation: 9 ViperThreat Good Standing Member
You can turbo a stock SVT engine, but you need to keep the boost within moderation. Its not hard to pop a stock engine if you do something wrong.
Also, you will need a stronger clutch to hold the power. Stock clutches are only good to about 200hp
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
Old 10-30-2012, 10:26 PM   #4
svtman123
svtman123's Avatar
Fan#: 105382
Ok. This is kind of my first rodeo so to speak with this sort of thing. What would you suggest to get overall? Like a ,gauge, clutch.... what would you suggest to get the most out of the turbo and which turbo would be the best for my certain situation on putting it on a stock engine?
Old 10-30-2012, 11:16 PM   #5
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
do some searching here and on focaljet.com. your questions have been answered before.
BigRed03 is offline
Old 10-31-2012, 04:24 PM   #6
nascaracing17
nascaracing17's Avatar
Fan#: 92774
What I Drive: 2003 Sonic Blue SVT 2door
FF Reputation: 1 nascaracing17 Good Standing Member
the stock clutch will hold fine unless your making more then 250ish whp. youll need a boost gauge and a/f gauge. and keep the boost no higher then around 10-12psi. and youll be 100% safe with a good tune of coarse
03 SVT, HKS exhaust, BOSS 302 Shifter Knob, Lowered on sportlines, a kick a** sound system...oh ya and lot of STICKERS!!!
nascaracing17 is offline
Old 10-31-2012, 10:35 PM   #7
ViperThreat
Dat boxer rumble
Fan#: 66026
Forum Activity 19%
I guess it depends on the condition of the clutch. Ive seen clutches slip on N/A 200hp, and I have to say that the difference between my stock clutch and the CM stg3 w/flywheel was amazing.
Old 11-01-2012, 12:29 PM   #8
nascaracing17
Fan#: 92774
ya u have a point there hows that stage 3 anyway? is it still ok for daily drivin or a bit too stiff
Old 11-01-2012, 01:28 PM   #9
ViperThreat
Dat boxer rumble
Fan#: 66026
Forum Activity 19%
When I replaced mine, i had 80k on the stock clutch, so it was a bit stiff anyway. the stiffer spring on the stage 3 feels about the same, so it's been totally fine for daily driving.
My only complaint was the chatter at idle. Its definitely louder than the stock clutch, so that can get annoying. But on the way the thing grabs is amazing.
Old 11-01-2012, 07:29 PM   #10
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,133, Level 18
Points: 1,133, Level: 18 Points: 1,133, Level: 18 Points: 1,133, Level: 18
Level Up 33% Completed
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Not thread jacking I just installed a CM Stage 3 Clutch and FW breakin it in got 200 miles on it my pervious clutch was a stage 2 spec and it had alot more presure on it then this stage 3
175WHP/153TQ N/A
StephenElsbree1986 is offline
