oil question , simple. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-28-2012, 01:12 AM   #11
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
Points 4,176, Level 41
Level Up 13% Completed
Originally Posted by Godzukidan View Post
I have always heard that the low number is the important one. I use Motorcraft filters and have never had a problem. I also use Motorcraft synthetic blend oil. Good bang for the buck. I have used Mobil one 5-20 in the past and the motor did seem to be a little smoother. Other than that I did not notice any other difference. I still got the same gas milage and the power felt the same. (So if it is for free, it is for me) that what I say.
well it would be hella sweet to actually have a noticable difference from the switch . is it possible ? i mean im pretty sure this cars never ran synthetic and its at 79,000 now
sam fisher is offline
Old 10-28-2012, 01:17 AM   #12
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,650, Level 94
Points: 23,650, Level: 94 Points: 23,650, Level: 94 Points: 23,650, Level: 94
Level Up 30% Completed
Forum Activity 16%
hey he wanted a simple cut and dry answer lol.
^^ what do you mean by the lower number is the important one?
mikebontoft is offline
Old 10-28-2012, 02:40 AM   #13
Godzukidan
ELVIS LIVES !
Godzukidan's Avatar
Fan#: 20925
What I Drive: 05 ZX3, 95 T-Bird V8, 2012 Stang V6
Points 2,392, Level 29
Points: 2,392, Level: 29 Points: 2,392, Level: 29 Points: 2,392, Level: 29
Level Up 62% Completed
FF Reputation: 6 Godzukidan Good Standing Member
As far as the low number. If your car calls for 5w20 it will not hurt to run 5w30. But I have heard do not run 10w20 or 10w30. I guess the low number is how thin the oil is at normal temp. And the high number how thick the oil is at start up. I to would like to know more info on the the numbers. Maybe someone with more info could clear this up.
I do know when I used the Mobil 1, my car at idol was real smooth. I would use it all the time if it did not cost so darn much. I change my oil every 3000 miles and it can add up.
For those about to ROCK............. We salute you..! (AC/DC)
FOCUS FACTOR
L.O.T.H # 67
Godzukidan is offline
Old 10-28-2012, 03:04 AM   #14
Points 10,070, Level 67
Points: 10,070, Level: 67 Points: 10,070, Level: 67 Points: 10,070, Level: 67
Level Up 5% Completed
Forum Activity 20%
http://www.upmpg.com/tech_articles/motoroil_viscosity/
That's not quite correct, the lower number is the viscosity under winter or cold (below 32F) conditions and the higher number is the viscosity at higher temperatures (above 210F).
A 5W20 and a 10W20 would behave exactly the same way at 210F at least theoretically, however on a cold engine the SAE 10 weight oil would be thicker than the SAE 5 weight oil which is bad for engine wear at start up.
However with viscosity improvers comes the risk of shearing and breaking down the oil to becoming thinner at higher temperatures.
You want the oil to be thicker at higher temperatures to prevent it from flowing away from the metal surfaces but not too thick as to cause flow issues, or damage from increased pressure.
suss6052 is online now
