Steeda Font & Rear Sway's - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 10-27-2012, 12:28 PM   #11
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Originally Posted by cobie56 View Post
Can the rsw ONLY be done and not negatively affect handling cuz the front was left stock?
Doing just the rear very positively affects handling. The stock suspension's tendency to understeer, or "push" if you will, is virtually nonexistent with the installation of only the rear swaybar. It also doesn't negatively affect the ride as much as installing both would.
Hatch Nation #90
TboneZX3 is offline
Old 10-27-2012, 01:10 PM   #12
GR34TWHI73N0RTH
GR34TWHI73N0RTH's Avatar
Fan#: 96598
What I Drive: 2012 Ford Focus SE Sport 5 Spd
FF Reputation: 1 GR34TWHI73N0RTH Good Standing Member
And the rear one is super easy to instal, so for 130 dollars u get a huge improvement, well worth it.
GR34TWHI73N0RTH is offline
Old 10-27-2012, 05:57 PM   #13
cobie56
Fan#: 84403
Thanks all. Now on my to do list asap
cobie56 is offline
Old 10-27-2012, 06:11 PM   #14
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
Buy-Sell-Trade Rating: (12)
According to "steedabrandon" we get a discount for being FF members. I'd go through him to order.
Sent from your iPad
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 10-27-2012, 06:59 PM   #15
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
FF Reputation: 1 Borski Good Standing Member
What kind of discount are we looking at?
Sent from my Motorola Atrix via FF Mobile
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
Old 10-27-2012, 07:08 PM   #16
scott7278
Fan#: 100021
I think I'm going to get the Steeda rear sway bar, and this RMM:
http://www.focusfanatics.com/forum/showthread.php?t=300246
It seems to be a pretty good mod for ~$200.
scott7278 is online now
Old 10-27-2012, 09:43 PM   #17
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
No idea, PM steedabrandon.
Sent from your iPad
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 10-29-2012, 10:24 AM   #18
SteedaBrandon
Fan#: 96136
What I Drive: n/a
FF Reputation: 1 SteedaBrandon Good Standing Member
Well here is some love and hate. I love the sway bars, they tighten up the handling and make the car really feel like i wanted it too. Its feel way more stable at high speeds, and around the corner's body role is cut down by more than half. I highly recommend these to anyone who really tears up the road's in the Focus.
The Rear one took maybe 20 min super simple no issue's at all. On the other had the front one was a pain in the ass. Ford put the oem one under the sub-frame so you have to drop it to even be able to reach it (wont even budge from the side, if you can get from out from there I'll consider you a god). So after you take apart the cross bars and drop the sub-frame its still has to be wedged out. Not easy! Then the major problem, the brackets for the front sway bar are identical to the rear ones but the bolts are not. I dont have the exact measurements of the bolts but the brackets fit the rear perfectly. The front bolts are extremely large, about a cm +, so you will have to machine down the brackets quite a bit to fit. The Brackets clearly weren't made to fits, their to small, the holes had to be made wider and longer, so hopefully i didnt weaken the integrity of them.
I waited a week to see what Steeda had to say, hoping that i might have accidentally been sent the wrong ones. Well sadly i have to say i was not. After a few emails and calls, the brackets are the only ones they have. I emailed them the photos on Monday and only received this in return "Thank you for the photos. I have passed them on to our manufacturing dept.". I called back today to get a some information, and was told it was normal, and up to the manufacture. He told me he would contact me if he heard, but no guarantee the problem would be solved. But i want to give them the benefit of the doubt, so ill update this if i hear otherwise. I would think Steeda would have ran into this problem if they had installed this before on the new focus, there is a pretty substantial and noticeable difference.
I'm not hating on Steeda, i love the parts and bars are quality. I have only heard good things about them, and that's why I'm surprised the brackets were over looked. Has any one else ran into this problem? I think i may have been the guinea pig with these. So if anyone had ran into this i would like to know?
I only have two photos, i probable should have taken a comparison one.
Again, if you want sway bars for the MK3, buy these. There worth it, but be aware you will have to put in a little work to make the front brackets fit.
Sorry to hear about your issues. May I ask who you contacted here about this?
I definitely want to look into this for you.
SteedaBrandon is offline
Old 10-29-2012, 12:04 PM   #19
GR34TWHI73N0RTH
Fan#: 96598
* * *UPDATE* * *
Problem Solved!
I was talking with Frank, but he email me this morning saying manf. is looking into it and have me something in a few weeks. Thanks guys! Took it through the canyons last night and they worked even better then i could imagine. Next Lowering!
But while you here Brandon can you tell me the difference between the Eibach and the Steeda coils. Because all i see is from the description is a .2" difference in the rear wheel
Old 10-29-2012, 12:59 PM   #20
cobie56
Fan#: 84403
Sent from your iPad
brandon gave me a 15$ discount so it cost 115$ plus 15$ s/h
that's lower than the 129.00$ 'sale' price listed on line...
good deal.
cobie56 is offline
