#11 | ||||
At around $25 for a 5-quart jug of Mobil1, it does seem a little backward to spend $25 on an oil analysis so you can determine whether or not you can save $25 by not buying oil.
And Qweesy, please come out of the 70's and join us here in 2012. Pennzoil conventional is of a completely different forumation than it was when it was causing sludge in your Pontiac Catalina, and Pennzoil synthetics are not even remotely related to their conventional oil in regard to forumation. Mobil1 ceased to be 'the best' when they downgraded from group IV base stocks to group III. At best, they're now known for being marketing champs for selling highly-refined group III oils as 'true synthetics'. |
#12 | ||||
If your intention is to run longer OCI's, you can spend $35 and get a TBN report, and estimate how long you can safely run that oil in your engine before the additives are depleted. If you can do this and extend your OCI by a few thousand miles, it won't take long before you've saved enough money on oil changes to make up the price of the analysis and more. So, there is at least a potential savings.
This is only one benefit among many of UOAs. We're all free to spend our hard-earned dollars as we please, but I feel it's worth our time to learn about the potential benefits of oil analysis before dismissing it as a waste.' I've done the same--I just hope Shell isn't lying about the NOACK spec. I will say that consumption has been very low for the past 5K miles I've been running PU.
'12 SE Sport 5Dr |╠╬╝|Sterling Grey Metallic|203a|Moonroof|17" Mach/Paint Whls|K&N Typhoon|MS3 RMM|Steeda STB, RSB '01 ZX3|╠╬╝|Pitch Black|Prem. pkg.|Moonroof|SVT Snorkel|SVT Springs|S2 Dampers|Steeda STS|Magnaflow exh. |
#13 | ||||
Are you going to guess on the TBN of your oil after 7500 miles? What if you want to run extended drain intervals? Will you guess what it is at 12000? or 15000? or 20000? Are you going to guess on the flashpoint of the oil, or determining if you have fuel dilution before major problems start? Would you guess if there is coolant getting into the oil? What if you’re leaching other metals? Wouldn't it make sense to catch a failing bearing before the engine starts knocking? It is unfortunate that you don't use such a valuable tool in your shop. While I only turned wrenches professionally for a short time, the shop I managed used this tool FREQUENTLY. Many major engine manufacturers, including Cat and Cummins, offer this service themselves. How did the world keep spinning before this technology? Oil was changed too frequently, and money was wasted. Potential problems were missed until the components failed. We used to have exchanged like this on paper and pen.. Would you prefer we went back to sharing information that way, also? Quote:
The original question posted was "So whats the story w/ Pennzoil advertising their ultra/ platinum synthetic oil runs cleaner than Mobil 1/ Valvoline synpower/ Castrol edge w/ syntec? Do they have more detergents in their oil over the other's or what?" You going to tell me that you can GUESS on the answer to this question? Ok. Guess away with your money, but don't recommend it other folks looking for an answer. It is highly possible that even at 7500 intervals you have wasted a ton of money over the lives of those vehicles. A proper oil analysis could have indicated the ACTUAL oil change interval you should have been using, and may have saved you hundreds (if not thousands) of dollars over the years. That, my friend, is value.
-Mike |
#14 | ||||
I can easily refute 3/4 of that but I'm tired right now. Simply put, not so in my world, even analysis results in a guess. Completely and totally unnecessary. You will always get some leaching and dilution, impossible not to. No guesswork there.
Save thousands? I don't even spend thousands, I'd be hard pressed to save hundreds. You got me generating cash now. Actually I do, I save drained oil to use for other things, $2.50 a quart you know............. You guys worry way too much about things that impact you way too little. You'll figure that out in another twenty or thirty years just like I did. |
#15 | ||||
FF Affiliate
Oil is easy , change it regular , if you change it before its used up then its still cheaper then an engine
If you run the engine hot change it right away If you race or run the car hard change it a little sooner Do this and you will be good with any oil you choose synthetic or non synthetic Tom
#16 | ||||
#17 | ||||
#18 | ||||
#20 | ||||
Just 2 harp in,,,oil anal can be good for identifying individual component wear. change your oil & filters. buy great filters. my oil is always no darker than apple cider. the kind you let you kids drink. i don't change my oil but every 10k or so. and i'm a castrol syn man.
