5 speed trans problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-25-2012, 06:06 PM   #1
b2tamer
b2tamer's Avatar
Fan#: 105297
What I Drive: 2000, black, focus
FF Reputation: 1 b2tamer Good Standing Member
hi guys, im new around here and i just bought a 2000 focus with a 5 speed about a week ago. well it didnt start having problems up until about 2 days ago, it first started out as it would grind trying to go into reverse when i first started it up, well now its hard to get it into any gear. when im going down the highway i can get it into 4th and 5th easy, but first and second are the really hard ones. i do alot of in town driving, i dont know if that would have anything to do with it, but i really want to figure out whats going on. oh and i get smoother shifts after i drive it for awhile, it goes into gear pretty easy. but at first its a real PITA to get into gear. thanks for any input, im really hoping this isnt a exspensive fix.
b2tamer is offline
Old 10-25-2012, 06:16 PM   #2
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 14 SE hatch
Points 2,392, Level 29
Points: 2,392, Level: 29 Points: 2,392, Level: 29 Points: 2,392, Level: 29
Level Up 62% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
i think its a slave, master cyl or the clutch line. hopefully for you is the master cyl. look to see if its wet (greeen plastic thing by the pedal.) if by pumping the clutch 5-10 times it solves the issue i think your getting air into the system.
also the fluid could need changing and when cold it can make it hard to get into gear, but i have never had it grind.
i would check the hydralics, bleed the clutch, ect. then look at the fluid level if you don't know how old it is you might as well change it.
Mike_Mac is offline
Old 10-25-2012, 07:41 PM   #3
b2tamer
b2tamer's Avatar
Fan#: 105297
well i just took it for a drive for about 10 minutes and went back home, after i got home it slid right into every gear and it went into reverse with no troubles. does that give you a better idea of what it could be? i really want to figure this thing out without having to spend a bunch of money, i checked the fluid for the clutch under the hood and its a little under the max amount u can put in it.
b2tamer is offline
Old 10-26-2012, 09:16 AM   #4
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
get in the car when its cold and before trying to go into gear pump the clutch about 10-15 times and see if it goes in smooth, if it does, probably a leak in the hydraulics.
then start looking for damp spots.
if that doesn't do anything but gets better with driving its probably the fluid. so change the fluid.
Mike_Mac is offline
Old 10-26-2012, 10:44 PM   #5
b2tamer
b2tamer's Avatar
Fan#: 105297
Okay it goes into gear smooth with the car off and I drove it about 100 miles today and everything went smooth, so I think its probably the fluid
b2tamer is offline
