Old 07-31-2012, 05:59 PM   #1
thehypeisreal
Fan#: 102002
What I Drive: 2005 ZX5
FF Reputation: 1 thehypeisreal Good Standing Member
Car stalling out when coming to a stop.
I made this in the general tech chat forum but I figured I might as well post it here as well considering its a duratec.... Ok so my car has had issues firing right up for a while now, I was starting to think my fuel pump was going out, but from what little bit I've read on here, this seems to be a common issue. However, that's not main reason why I'm here. A couple weeks ago it started cutting off whenever I would come to a stop(redlight, stop sign, etc.), electronics would surge at an idle(if the car didn't cut off), I would sometimes have to jump it off and my charge light came on. So I took it to a shop and they told me it was the alternator. I decided to replace it myself. I start undoing everything and one of the first things I came across was a broken ground wire(I'm assuming). It comes off the wiring harness that is connected to the fuel rail and bolts to the power steering reservior bracket. So I go to a junkyard, get the wire and swap it out. The charging light went out but all of the other problems still existed. So I take it to a different shop someone reffered me to to get a second opinion and they told me the same thing, alternator. So I went ahead and replaced it, charged my battery back up and now I'm still dealing with the cut off issue. Oh yea, if it helps, before all of this other stuff started happening, whenever I was low on fuel(say 1/8th of a tank or lower) and I would go around a sharp left hand curve or say an on-ramp with some speed the car would act like it was trying to cut out, like it was being starved of fuel.
I also need to note that in addition to the stalling issue, the rpm's are moving around a lot between about 200 and 1k. I have seen a few other threads with this same issue but I honestly dont know where to start to figure out the problem. Fuel filter and spark plugs have both been replaced within the past year. So what should I check next?
thehypeisreal is offline
Old 07-31-2012, 06:01 PM   #2
thehypeisreal
Fan#: 102002
BTW, its for an 05 2.0 5 speed, if that helps
Old 07-31-2012, 06:03 PM   #3
BLÜE_BÄLZ
make your own luck
BLÜE_BÄLZ's Avatar
Fan#: 65778
What I Drive: 2002 Twilight Blue ZX3
FF Reputation: 11 BLÜE_BÄLZ Great Standing Member
Buy-Sell-Trade Rating: (7)
Id start by cleaning your IAC and or MAF.
More than likely that will solve your prob
helps in 00-04's may work on your 05
OEM+
i boobies! - http://www.keep-a-breast.org
BLÜE_BÄLZ is offline
Old 07-31-2012, 06:15 PM   #4
thehypeisreal
Fan#: 102002
Ok I kinda know what a MAF is, but whats an IAC?
Old 08-01-2012, 09:05 PM   #5
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
FF Reputation: 200 warneej Excellent Standing Memberwarneej Excellent Standing Memberwarneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
PCV hose has ripped behind your intake manifold.
/problem.
Looking for 17x8 wheels to race on! PM me if you have something!
173.4whp
gump
crew #6
warneej is online now
Old 10-25-2012, 07:23 PM   #6
pureford.
Fan#: 101008
What I Drive: 2005 white ZX4
FF Reputation: 1 pureford. Good Standing Member
Diddo
i've been having similar problems with the stalling out at red lights and have been working to fix it. i have the same 2005 zx4 2.0L 5-speed. i put in new spark plugs, fuel filter, and i cleaned all my intake sensors. also have a brand new air filter in my cai.
pureford. is offline
Old 10-26-2012, 10:09 AM   #7
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '07 ST and '86 XR4Ti
Buy-Sell-Trade Rating: (11)
/problem.
This^
I don't recall ever hearing of a Duratec Fuel Pump failing since I bought my first '05 SE back in 2007.
Fuel filter may need changed as well; only a couple bucks and a hour under the car.
'07 ST ; formally bewst'd
'86 XR4Ti ; 2.3L Turbo, 15psi
D23 Crew: #07
Jgrove998 is offline
Old 10-26-2012, 09:19 PM   #8
thehypeisreal
Fan#: 102002
Ended up being a dirty MAF for me. Cleaned it with maf cleaner, reset the mixture. Problem solved.
