SYNC Update Available on Focus!!! - Page 65 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 10-26-2012, 03:53 PM   #641
Bigbot45
Fan#: 87124
What I Drive: 2014 Q50 - Formally 2012 Ti Hatch
Points 487, Level 9
Points: 487, Level: 9 Points: 487, Level: 9 Points: 487, Level: 9
Level Up 74% Completed
FF Reputation: 2 Bigbot45 Good Standing Member
Originally Posted by copernicium112 View Post
Yep. It used to take about 5-7 days before I lost them and had to reboot to get them back. Since 3.2.2 it doesn't even last 2 days. I have done 3 reboots since Monday (I do reboots, I hate Master Resets because it wipes out all of the presets, wallpaper, phone, etc.) In all honesty, it didn't work that great with 3.0.2 for me and like I said I had reboot with that version as well, just not this often.
Call Ford and they'll tell you it is Sirius' fault and they are not sending the signal. Tell them that it is amazingly coincidental that after every reset/reboot the signal is suddenly there. Ask them how Sirius knows you just did a reset/reboot and suddenly knew to send out a signal. You will get nothing but silence on the other end of the phone (trust me, I've done it).
I've tested every single thing I could think of to fix this/get it working better. Everything I have tried leads me one conclusion - this is entirely a problem with MFT and has nothing to do with Sirius.
Worked flawlessly when I had 2.11.
Wasn't 3.22 supposed to specifically fix this? On 3.0.2 I've lost my traffic whenever I've had a serious need for it.
2012 Ford Focus Titanium Hatchback
2006 VW Jetta 2.0 Package 2 <-- 2001 VW GTI VR6
1990 Subaru Legacy <-- 1986 Ford Taurus
1990 Mazda Protege <-- 1986 Subaru GL-10 Turbo
1986 Volvo 240 DL
Bigbot45 is online now
Old 10-26-2012, 08:03 PM   #642
heliosj228
heliosj228's Avatar
Fan#: 97016
What I Drive: 2012 Race Red Focus SEL
FF Reputation: 1 heliosj228 Good Standing Member
I run Linux.. does anyone just have the ability to download drive images so I can dd them myself? The friggin' Java app just doesn't see the USB drive in Linux. *sigh* You write software in an OS neutral language and then restrict it to only two.
heliosj228 is offline
Old 10-26-2012, 08:24 PM   #643
forceflow2
Fan#: 89089
What I Drive: 2013 Mustang GHIG V6 Premium
FF Reputation: 1 forceflow2 Good Standing Member
The download isn't an image.
2012 Ford Focus Sterling Grey Metallic SEL Sedan
Ordered: 8/6/11 VIN: 9/6/11 Build Date: 8/30/11
Delivery: Originally estimated 9/19/11. Delivered 9/22/11. picked up 9/24/11.
Reacquired by Ford under Lemon Law 01/16/13.
forceflow2 is offline
Old 10-26-2012, 08:51 PM   #644
heliosj228
heliosj228's Avatar
Fan#: 97016
Then what is it? Just a bunch of files thrown to a formatted USB drive?
Old 10-26-2012, 08:55 PM   #645
forceflow2
Fan#: 89089
Yes. The requirement of selecting a drive is just there to make the installation more or less idiot-proof so people don't forget to copy some files or put them in a subdirectory or the like.
Old 10-26-2012, 09:14 PM   #646
heliosj228
heliosj228's Avatar
Fan#: 97016
Well, I can properly unzip a set of files. And none of this changes the fact they're using Java (again, an OS neutral platform) and not allowing all operating systems to use it.
Old 10-26-2012, 09:53 PM   #647
forceflow2
Fan#: 89089
I don't think you understand what that actually means. I can pretty much guarantee you that Ford is using listRoots() to get the drives, which for *NIX systems will return "/" only. It's not going to know about your mounted volumes. If they say they support Macs (no clue whether it says so or not) then it's probably because they can just enumerate /Volumes. Java is architecture neutral, but it isn't development neutral. What do you want them to do, check the os.name and start calling system binaries if it's *nux/*nix to check that info? There's no way in hell I would let an applet do that, especially knowing Ford's programming track record. Not to mention complaining about them not going out of their way to accommodate an OS with negligible desktop penetration is ridiculous. If you've been using *NIX systems for any length of time you should understand and be used to this.
Old 10-26-2012, 10:44 PM   #648
heliosj228
heliosj228's Avatar
Fan#: 97016
Well thank you for the wonderfully condescending reply. I know exactly what I meant and I stand by it. How hard would it be to insert a call that determines which OS is being run and simply ask for a USB path? -- or [insert 3 other good ideas]. I'm sure they didn't choose Java on a whim, they were considering future scenarios that would also likely not support the method you described. But whatever... I'll take it to the dealership, it's their dime.
Old 10-26-2012, 10:55 PM   #649
forceflow2
Fan#: 89089
That's what I am here for.
You can stand by being wrong all you want, I won't stop you.
Zero hard, but that's idiotic.
You should probably insert a single one first.
Probably not.
...What?
There we go, there's a good idea. Go with that and call it a day.
Old 10-26-2012, 11:05 PM   #650
heliosj228
heliosj228's Avatar
Fan#: 97016
Thanks!
I'm rubber you're glue..
Why? Just saying it doesn't make it so.
See above.
...What?
Any number of scenarios, upgrades via embedded devices, internal tools, etc.
You know, I was a little frustrated and was slightly hostile to the process. But instead of handling this in a decent way and discussing it without the smell of arrogant douche, you went all in. Nice work cool guy.
