#91 | ||||
I plan on taking the say off this Friday to do this replacement. Did you guys bench bleed the cmc prior to installation or simply gravity bleed it when it was all together?
Sent from my DROID RAZR using FF Mobile |
#92 | ||||
M0derator Monkey
I got my brother to help me pedal bleed the system from the nipple on the transmission AFTER full installation. It took a little while but we just kept going until zero bubbles came out. When bleeding the clutch system STAY AWARE: don't let the brake fluid reservoir get low.
Moderator for Showroom, General Chat Lounge, and South West Region 15.07 @ 93.49 |
#93 | ||||
#94 | ||||
M0derator Monkey
^^Negative, I capped the reservoir output line with the rubber cap from the clutch bleeder nipple to prevent it from draining. The only reason you would drain the reservoir during this procedure would be if you were replacing the brake fluid with new fluid.
#95 | ||||
Just did this on my 05 ST yesterday. The access hole in wheel well was only useable after disconnecting the abs sensor and 2 giant connectors for ( I assume) the dash and pulling all three into the engine bay out of the way. I also had an issue getting the lower hose to reconnect to the new cmc. There's a bracket on my car holding it that I unbolted so I could adjust the angle it was entering.
Bled it using mity vac until solid flow came out, then pumped it up by hand and used a brake pedal depressor to hold the pedal down while I went to the front and popped the bleeder open. I didn't get a really solid feel until I manually bled it, but I only had to do it 4 or 5 times til I did. feels better than ever!
1991 Super Coupe - 95 Cobra engine w/M5R2 5speed, and lots of goodies. 2005 Focus ST - Marcy MS CAI, Xcal2(Toms tune), F2 header, 2.5" Truebendz, $0 Thunder TB, Saleen/Eibach kit with Racecraft springs |
#96 | ||||
This quote above confuses me a bit. I've watched many a video's and talked to some coworkers who drag race their own cars and feel confident with bleeding lines now. But Step 6 states to not pull the CMC out until most of the fluid is drained. From where? And step 10 states to drain most of the brake/clutch reservoir using a turkey baster. So these do not need done? If the fluid is not removed from the reservoir, and you disconnect the green lines (step 12), wouldn't fluid drip out everywhere? and when you removed the CMC without removing fluid in the reservoir, wouldn't all of the fluid flow out from the old CMC prior to new CMC installation? Sorry for the rookie questions, I just want to make sure that this is done right the first time by me. Once I do it the first time, I will know for good what to do. Can you please help me understand just what exactly you did with the fluid and how you did it? Otherwise, following the steps with disconnection and replacement is pretty self explanatory. Thank you all. |
#97 | ||||
Nevermind for my dumb questions. I just fully understood this when I gave it a quick re-read. Sorry. Thanks for your help!!!!
#98 | ||||
M0derator Monkey
No prob!
#99 | ||||
Is the bleeder valve located kinda to the bottom right of the engine under lines? I have an 07 focus. I don't want to start bleeding brakes or anything. It is the only valve i can find. Please answer kinda quick. Doing this now actually. Thank you all
#100 | ||||
M0derator Monkey
Sorry man, just got home from work. The bleeder valve is on top of the transmission. Bleeding the brakes won't help you bleed the cmc.
| Tags |
| clutch master cylinder |
