Hesitation at speed - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-25-2012, 05:27 PM   #1
dckotwicki
Fan#: 50924
What I Drive: 2010 White SEL
Points 440, Level 8
Points: 440, Level: 8 Points: 440, Level: 8 Points: 440, Level: 8
Level Up 80% Completed
FF Reputation: 1 dckotwicki Good Standing Member
Angry Hesitation at speed
I own a 2010 Focus SEL with 50K miles on it. I am noticing a slight / subtle hesitation while at speed. I can be doing 50MPH, 70MPH, cruise on or cruise off and I feel a hesitation from the engine. It is as if it is windy out and the car is buffetting slightly but is is not windy. It is also something that is more recent.
The engine idles perfectly.
( I am current with oil / oil filter and air filter changes)
If I bring the engine to 2500 or 3000 RPM it seems very smooth.
Since this began, I have also noticed an occasional roughness in the engine at start-up that smooths out right away.
When it began, I called the Ford dealer and asked if the car had a fuel filter that could be changed and was told "No". Is that correct?
Any ideas? ? ?
dckotwicki is offline
Old 10-25-2012, 05:53 PM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
Buy-Sell-Trade Rating: (13)
I believe you have a "in tank" fuel filter on that model.
Only thing I would suggest is getting some new spark plugs (I would recommend Autolite 104's properly gapped).
You could also check and be sure there is no corrosion on your battery terminals.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
D23 Crew: #07
Jgrove998 is offline
Old 10-25-2012, 05:57 PM   #3
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
What I Drive: 01 cd silver 3 door ztec
Points 7,665, Level 58
Points: 7,665, Level: 58 Points: 7,665, Level: 58 Points: 7,665, Level: 58
Level Up 58% Completed
FF Reputation: 2 sgtsmasher Good Standing Member
how about when your coming to a stop?
does it do anything then, or when your slowing down?
any unusual vibrating?
the only reason i ask is cause ive had brake problems before and thats what it feels like, is that the car accelerates hard and brakes fast and when at speed the rotors can heat up some wicked and slow the car down to where you can notice a difference. i cant hurt to check. ive had brake new calipers fail on me before, its very common but can happen!
Hatch Nation #72
Call Me BRANDO COMMANDO
sgtsmasher is offline
Old 10-25-2012, 06:00 PM   #4
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
50k miles over 2 years is average mileage. You shouldn't be having any problems with anything just yet- as far as spark plugs and coil boots go. I would consider pulling the coils and boots off each plug and seeing if there is any oil in any of the wells. You might have a bad valve cover gasket that is causing some problems.
Although earlier fuel filters were required to be changed every 20-30k miles, I do believe that Ford switched to a "lifetime" filter in your vehicle. Hopefully someone with an 2010 will chime in to verify.
Old 10-26-2012, 02:11 PM   #5
FordService
FordService's Avatar
Points 3,469, Level 36
Forum Activity 18%
Originally Posted by dckotwicki View Post
I own a 2010 Focus SEL with 50K miles on it. I am noticing a slight / subtle hesitation while at speed. I can be doing 50MPH, 70MPH, cruise on or cruise off and I feel a hesitation from the engine. It is as if it is windy out and the car is buffetting slightly but is is not windy...
Hi dckotwicki,
I would advise that you make an appointment at your dealership so they can take a look. Ford certified techs are in the best position to diagnose and repair your Focus. If you have any questions, feel free to reach out to me via PM.
All great info, folks. Thanks!
Have a great weekend,
Crystal
FordService is offline
Old 10-27-2012, 12:48 AM   #6
dckotwicki
Fan#: 50924
Points 440, Level 8
The vehicle behaves properly when braking and coming to a stop. I recently replaced the front rotors and pads. The car was acting like this before the new brakes and after the new brakes. There is no interference from the brakes... everything spins freely.
Anyone know what the spark plug gap is?
Old 10-27-2012, 07:21 AM   #7
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,374, Level 20
Level Up 74% Completed
Yep...get it in to a Ford Tech. They love working on FF's. They'll fix ya right up.
coldbear is offline
