2012 Focus 17 vs 18 inch Wheels - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: 17 vs 18
17 13 43.33%
18 17 56.67%
Voters: 30. You may not vote on this poll
Old 10-25-2012, 09:44 AM   #1
thisisbenji
thisisbenji's Avatar
Fan#: 102558
What I Drive: 2012 Red SE
Points 674, Level 13
Points: 674, Level: 13 Points: 674, Level: 13 Points: 674, Level: 13
Level Up 48% Completed
FF Reputation: 2 thisisbenji Good Standing Member
I want to know which would be better as far as handling goes. I plan on doing a little autocross and want to make sure I get some decent wheels. I'd like to step up to 18s but I'm not sure if there would be any negatives.
Edit:
If I stick with 17s, is it acceptable to switch to 225/45R17s or 235/45R17s (seems to have closer overall diameter to the stock tires) from the stock 215/50R17s? This way I could get better tire.
2014 Focus ST2 | Race Red
2012 Focus SE Sport | Race Red | DCT | Steeda RSB - SOLD
thisisbenji is offline
Old 10-25-2012, 09:52 AM   #2
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 bbcobra Good Standing Member
you'll find that the 18" tires are more expensive. but they sure do look good.
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
Old 10-25-2012, 11:18 AM   #3
Mucrammada
Mucrammada's Avatar
Fan#: 91537
What I Drive: 2013 Limited WRX Hatch, 2011 CTS
FF Reputation: 1 Mucrammada Good Standing Member
Edit:
The higher the wheel height the more performance is lost. The taller wheels are the more the torque has to work to spin the wheel, therefore decreasing torque, and displacing HP. I'd go with some wide 16 or 17's.
I can haz cheezburger?
Official Mayo Hater #5
Mucrammada is offline
Old 10-25-2012, 12:31 PM   #4
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Points 4,182, Level 41
Points: 4,182, Level: 41 Points: 4,182, Level: 41 Points: 4,182, Level: 41
Level Up 16% Completed
Also with 18"s your turning radius will be wider and will rub at full lock.
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 10-25-2012, 12:34 PM   #5
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,376, Level 77
Points: 14,376, Level: 77 Points: 14,376, Level: 77 Points: 14,376, Level: 77
Level Up 82% Completed
Forum Activity 19%
Thee 17"s stock height is 50 aspect ratio. Which is pretty tall for performance only use.
The 18" drops the aspect to a performance friendly 40.
The other side of the positive for the 50 aspect is damage control. A 50 aspect tire can take a LOT more punishment that a 40 aspect tire.
So if you plan on any rough course, better to stick with a tire less likely to fail due to hitting any rocks, potholes etc at speed.
If you go with the 17 and 50 aspect ratio, then find tires with stiff sidewalls, instead of the current fad of total 'soft' mush sidewalls.
The stiffer sidewalls will give the turning power of the 40's in a 50 aspect ratio.
The OEMB.F. Goodrich tires for the Contor SVT had some of the stiffest sidewalls ever, and were fabulous tires for any sporting as far as cornering went.
Though they were noisy as can be on the street.
Elizabeth is offline
Old 10-25-2012, 06:54 PM   #6
Joey D
Joey D's Avatar
Fan#: 86391
What I Drive: 2012 Tuxedo Black Titanium 5-Dr
FF Reputation: 2 Joey D Good Standing Member
18's won't rub, mine work just fine at full lock.
And 18's are the way to go, they look so much better on the car than 17's and really fill in the wheel wells nicely. Here's what my car looks like with 18" Team Dynamic Pro Race's.
Joey D is offline
Old 10-25-2012, 06:59 PM   #7
thisisbenji
Fan#: 102558
Those look really good, where did you get them if you don't mind sharing? Decisions decisions.
Old 10-25-2012, 08:16 PM   #8
Joey D
Joey D's Avatar
Fan#: 86391
I got them from Perfect Circle Autosports. I want to say it was about $1,000 for the set which was a pretty good deal, tires were another $900 but I bought those at Discount.
Joey D is offline
Old 10-25-2012, 08:25 PM   #9
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Still have the wheel gap with 18"s since the the profile doesn't change you just have more sidewall with 17"s. I'll be dropping mine with some Eibachs next spring. I love the look of the 18"s but I do like having a little more rubber on my rims and the 17" tires are a little easier on the wallet.
Old 10-25-2012, 08:28 PM   #10
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Plus if you plan on autoxing then the 17"s will be lighter unless you spned bucks on a lightweight set. I love the 18"s Joey has but at $1000 a set no thanks. For that cash outlay with tires I could've bought an exhaust and an intake along with my set.
It's the wheel gap that bothers me right now but these wheels in 18"s were so tempting but our roads suck (dirt drives show up time to time too) around here and with my wife as the primary driver I don't have to worry so much about her tagging a curb.
