loss of power at lower engine speedss - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-08-2012, 01:54 PM   #11
Kyllgore
Fan#: 1506
What I Drive: '03 ZX3 MTX pitch black,
FF Reputation: 1 Kyllgore Good Standing Member
ok PDFE sensor changed, new PCV hose
still have the issue checked all vacuum hoses all are good
what else should I look at?
Sometimes when it loses power I feel feedback in the gas pedal.
EDIT
Here is more info, car is usually fine at 1/3 throttle below 3k rpms
Over 3k it runs great, but below anything more than 1/3 throttle surges and feels like "popping" in the gas pedal.
So I doubt fuel is an issue and now from stops taking off I almost always need the AC off.
I need help can't afford stealership
would alternator effect this in anyway?
and for some reason this thread does not come up when I search?
why isn't my thread showing up anymore?
if only this modding stuff didn't take so much money
Mac SRI, FC 65mm TB, SVT 5 spokes
SVT brake kit, SS lines up front, SVT suspension
Kyllgore is offline
Old 08-11-2012, 01:15 PM   #12
Kyllgore
Fan#: 1506
sorry bump
Kyllgore is offline
Old 08-17-2012, 01:33 PM   #13
Kyllgore
Fan#: 1506
could the alternator be the problem? I believe mine is showing signs that it's going
Kyllgore is offline
Old 10-15-2012, 06:19 PM   #14
Kyllgore
Fan#: 1506
alternator tested good, so I dunno what to do next
Kyllgore is offline
Old 10-15-2012, 07:31 PM   #15
rangerbay
Fan#: 76247
What I Drive: 2001 white zts,2001 white wagon,
Points 211, Level 4
Points: 211, Level: 4 Points: 211, Level: 4 Points: 211, Level: 4
Level Up 22% Completed
FF Reputation: 2 rangerbay Good Standing Member
Originally Posted by aaronmach1 View Post
is he talking about the pcv line?
crankcase vent tube. It starts out in right front as a steel tube, and under the throttle body, it connects to the rubber hose that goes behind the engine.
They collapse. I just had one go bad. No leak, just flat as a flitter.
rangerbay is offline
Old 10-15-2012, 09:35 PM   #16
Kyllgore
Fan#: 1506
the metal tube up front collapsed? I have already replaced the rubber hose for the collapsing problem and that helped a bit, I'll check it out again and make sure it's still on securely
Kyllgore is offline
Old 10-16-2012, 07:36 PM   #17
rangerbay
Fan#: 76247
Points 211, Level 4
No, sorry I confused you. The rubber tube crimped at the back of the motor. Did you replace it with the new style insulated hose?
Bill
Old 10-22-2012, 01:29 PM   #18
Kyllgore
Fan#: 1506
Yes I have replaced that hose with the better built and designed one
Kyllgore is offline
