#21 | ||||
APOCALYPSE DUDES
Sweet , so I figure in this situation wiring will be where I get stumped , how much of this if any is plug n play
#22 | ||||
TRS's wiring harnesses are top notch. There really isn't any cutting and splicing.
Everything is "Plug and Play". You plug the TRS 9007 adapter into your driver side headlight socket and hook up one power, and one ground (power - battery / ground - frame) and all the other plugs go to your new hardware (ballasts / hi beam solenoid) If anything, the wiring is going to be the easiest part of your retro. The fitting of the projector and getting everything to align properly is going to be the most difficult part of the project.
2002 SVT Tom's Tune // CFM 67 TB // AEM CAI // VF R&DrEM // Steeda STS // Boss 302 SKnob // Eibach Pro-Kit // KYB AGX DomEng ORP & Flex // MASSIVE STB // Hella Xenon Euro-Spec HIDs // Fusion Fog Light Mod // EuroStar LED Tails |
#23 | ||||
APOCALYPSE DUDES
#24 | ||||
Yes, you will be able to use the factory adjustments because you will be mounting the projector to your reflector housing in your headlight.
#25 | ||||
APOCALYPSE DUDES
#26 | ||||
Aligning the beam up and down can be done with the factory adjustments once the projector is mounted to the headlight housing.
#27 | ||||
APOCALYPSE DUDES
Sent from my N860 using FF Mobile |
