2012 HID Thread (Info Only No Arguing) - Page 28 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-19-2012, 06:43 AM   #271
Bwill9886
Bwill9886's Avatar
Fan#: 93444
Originally Posted by 2011Fiesta View Post
How difficult is it to install HIDs in the fogs. I have yet to check it out on my own as I have a busy schedule. Anyone do a write up?
Mentioned it on the previous page.
Originally Posted by Bwill9886 View Post
And no, the fog lights are easy to do. You can do the driver's side from the access under the headlight, but you do need to get under the car or access the fender well for the passenger side.
Personally I'd recommend that if you are going to get under the car for the passenger side that you may as well do the drivers side from down there as well. It's easier to mount the ballasts and mess with wiring that way.
It's straight forward plug-n-play (no relay is required) so there really isn't anything more to it than removing the stock lights and putting in the HID's.
Bwill9886 is offline
Old 10-19-2012, 07:40 AM   #272
2011Fiesta
2011Fiesta's Avatar
Fan#: 97993
What I Drive: 2011 Silver Fiesta sedan
FF Reputation: 1 2011Fiesta Good Standing Member
Seems easy enough. Hard part for me is finding time to do this..
Sent from my HTC Rezound using FF Mobile
2011Fiesta is offline
Old 10-19-2012, 08:06 AM   #273
slow3v
slow3v's Avatar
Fan#: 101709
What I Drive: 2012 Sterling Gray Focus SE MTX
FF Reputation: 1 slow3v Good Standing Member
I just don't like the relays because of the extra wiring "mess."
That and if you tapped power from the driver side headlight wouldn't it show a pass. side error when using a relay kit?
slow3v is offline
Old 10-19-2012, 06:29 PM   #274
Bwill9886
Bwill9886's Avatar
Fan#: 93444
Fair enough on the extra wiring, though I've got mine pretty nicely tucked in.
The relay does not tap into either headlight harness. Only the resistors, which then connect to the headlight harnesses.
Here is the install diagram again for those new to the thread:
Old 10-20-2012, 07:56 AM   #275
Darketernal3
Darketernal3's Avatar
Fan#: 98631
What I Drive: 2012 Ford Focus SE Sedan
Points 484, Level 9
Points: 484, Level: 9 Points: 484, Level: 9 Points: 484, Level: 9
Level Up 68% Completed
FF Reputation: 1 Darketernal3 Good Standing Member
I routed the wire in the front of the hood, along with the latch wire... Everything else is tucked either in the wheel well, or on the bottom side of the headlight assembly, pretty easy to do and not a mess, just takes a little time to organize.
As far as the relay/power issue... I should probably give it a simpler approach...
Think of each headlight as a lever that activates something.
In normal use, you throw the lever, it switches on a light attached to your battery.
With this relay setup, you throw the switch activate another switch that turns on a light attached to a different battery. The first light bulb that normally comes on... well it's been replaced with an iron ball....
Silver Ingot
203A Package
SE Sports Package
Two toned sports interior Stone/Black
Darketernal3 is offline
Old 10-20-2012, 09:17 AM   #276
bobtech
Fan#: 99007
What I Drive: 2012 Grey Focus Titanium
FF Reputation: 1 bobtech Good Standing Member
is this going to be around the same type of installation for the new 2013 FUSION HYBRID?
sent from my SIII in sunny FL.
bobtech is offline
Old 10-20-2012, 08:15 PM   #277
Bwill9886
Bwill9886's Avatar
Fan#: 93444
Finally got around to making a video for how I did my HID's. Excuse any mis-sayings and the like as it was spur of the moment.
I have some details in the video description. Feel free to ask questions.
YouTube Video
Old 10-20-2012, 08:20 PM   #278
bobtech
Fan#: 99007
Do you know about what I would need 4 a 2013 FUSION hybrid ?
bobtech is offline
Old 10-20-2012, 08:30 PM   #279
Bwill9886
Bwill9886's Avatar
Fan#: 93444
The same equipment that you need for the Focus.
Might have a different bulb size and the routing of wiring will be different.
Can't comment on anything more specific as I don't have a 2013 Fusion.
Old 10-22-2012, 07:45 PM   #280
jayw32
Fan#: 103280
What I Drive: 12 sonic blue se
FF Reputation: 1 jayw32 Good Standing Member
so getting a relay for the h11 bulb and the resistor as in the first post the wiring up the resistor to the bulb connector....would i need to purchase two resistors? or just the resistor kit in the first post?
jayw32 is offline
