#1 | ||||
Driving in sport mode shifting from 2-3 problem?
i noticed when i shift from 2nd - 3rd using select shift in sport mode it takes a second. It revs the engine and then shifts but shifting from 1-2 and 3-4-5-6 shifts fine its just 2-3 any reason for this? is it normal? am i shifting too early or too late? just curious what you guys thought.
Remove Advertisements |
#2 | ||||
You might want to take a technician for a ride so he can see what it's doing. It sounds like something is causing a delay with whichever clutch powers 3rd gear, although it's strange that it doesn't affect the 4-5 shift as well. Reving between shifts can cause accelerated clutch wear. Any other wierd behavior? Shuddering from a stop?
#3 | ||||
#4 | ||||
Judging from what I'm seeing on this forum, a lot of people's clutch problems stem from a leaky transmission input shaft seal, which basically allows oil to get onto the clutches. This can cause them to be grabby, or slip depending on the quantity of oil. Take it in, and see if you can get a service advisor or tech to take a ride with you.
#5 | ||||
#7 | ||||
#8 | ||||
#9 | ||||
#10 | ||||
How high do your revs climb when shifting from 2nd to 3rd?
I picked up my 2012 Focus Ti hatchback (7/12 build) yesterday and started noticing the same thing. When I drive in S mode and shift at around 2000 rpms from 2nd gear it continues to rev for about a second to 2700rpms before 3rd is engaged even though the display shows I'm in 3rd. If I shift from 2nd at 3000rpms it revs for about a second to 3800rpms before engaging 3rd gear. Other 1-2, 3-4, 4-5, 5-6 are all smooth and instant. I'm lucky I don't have the shuddering or other accelerating issues some people on here have (knock on wood) but this is still pretty significant. Please let us know what the dealer says. I'm booking a service appointment next week. |
