Why you should retrofit your lights - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-14-2012, 11:30 PM   #11
cmmike1
cmmike1's Avatar
Fan#: 63736
What I Drive: 2008 Silver Coupe SES
Points 1,061, Level 17
Points: 1,061, Level: 17 Points: 1,061, Level: 17 Points: 1,061, Level: 17
Level Up 61% Completed
FF Reputation: 1 cmmike1 Good Standing Member
i used 4 screws to mount as well for mine. just a little extra strength i figured since i'm on stiff coils. where did you mount your grounds?
cmmike1 is offline
Old 10-14-2012, 11:54 PM   #12
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
Passenger is on a purple wire ground to the left of the engine. Right out in the open.
Driver side is where the fender connects to the frame I think, there's a body bolt with a speed nut. The bolt comes up from the bottom into the speed nut, very visibile when headlight is out.
A7xschecter6661 is offline
Old 10-15-2012, 06:25 AM   #13
DarderSauce
DarderSauce's Avatar
Fan#: 95564
I am thinking about getting my kit soon but need to locate 1 more headlight before I can get started. Once the retro is done, I am going to plop another set of Lamin-X 12% tint on the lenses.
DarderSauce is offline
Old 10-15-2012, 08:06 AM   #14
LikwidZX5
LikwidZX5's Avatar
Fan#: 34180
What I Drive: 2006 ST w/ SAP2
Points 1,960, Level 26
Points: 1,960, Level: 26 Points: 1,960, Level: 26 Points: 1,960, Level: 26
Level Up 60% Completed
FF Reputation: 4 LikwidZX5 Good Standing Member
Glad to see someone else doing a retro with Morimoto Mini's. Mine are too low as well, my driver side light is as high as it will go before the screw pops out of the reflector bucket. I'm still trying to devise a plan using a nut-bolt-washer combination instead of the factory vertical adjustment.
Looks good
old: 2002 ZX5//current: 2006 ST
MW/SR/D23/ST Crew
LikwidZX5 is offline
Old 10-16-2012, 11:19 AM   #15
Slammed_2.0
Boosted HB.
Slammed_2.0's Avatar
Fan#: 84306
What I Drive: 2013 TB ST
Points 6,542, Level 52
Points: 6,542, Level: 52 Points: 6,542, Level: 52 Points: 6,542, Level: 52
Level Up 96% Completed
FF Reputation: 20 Slammed_2.0 Great Standing Member
With it properly aimed you should be able to see 1/8 mile down the road on a pitch dark night.
OP, may I download that picture of the bowl mount and include in my how to retrofit guide?
2013 Ford Focus BOOS[ST]ED
2010 Ford Focus "S"edan (11 Psi, GT28RS) - Sold
ROTM Nov '11 (2010 Focus S)
Slammed_2.0 is offline
Old 10-16-2012, 08:10 PM   #16
Barrow88
Barrow88's Avatar
Fan#: 91009
What I Drive: 10' Black SES, 02' Boosted ZX3
Points 964, Level 16
Points: 964, Level: 16 Points: 964, Level: 16 Points: 964, Level: 16
Level Up 64% Completed
FF Reputation: 4 Barrow88 Good Standing Member
I left the bars in mine also but I painted my shrouds black and left the reflector chrome, I also did a Blazer retro for my fog lights I still need to get them aimed but I think they look good. Here are some pics.
'10 SES
Build Thread: http://www.focusfanatics.com/forum/showthread.php?t=321737
'02 ZX3
Build Thread: Already Built... For Now
Barrow88 is offline
Old 10-16-2012, 08:12 PM   #17
DarderSauce
Fan#: 95564
Wow, Projectors in the fogs even. Must be so bright!
You're such a dick, why would you show me that. Now I want....
Could you imagine 2 55watt sets of HID's on your car? But I would be too afraid those exposed lenses would get shattered to bits
Old 10-16-2012, 08:30 PM   #18
A7xschecter6661
Fan#: 98263
Absolutely! You have helped me out a few times via PM.
I finally have mine aimed a little better. I will go take new pics.
Ok here we go, by the way in my earlier pictures it was a combination of my headlights not aiming correctly and pointing downhill slightly.
So I backed up a little.
The edge of the woods is about 100 feet away
Trust me, this puts out a ton more light than what the camera picks up.
Next step will be figuring out how to run fogs all the time, if it's built into the computer to not run while foglights are activated I will just run a HID wiring harness and switch inside the car.
Old 10-16-2012, 08:35 PM   #19
Baldurs390
Baldurs390's Avatar
Fan#: 86071
What I Drive: 2009 black ses
Points 3,635, Level 37
Points: 3,635, Level: 37 Points: 3,635, Level: 37 Points: 3,635, Level: 37
Level Up 90% Completed
FF Reputation: 4 Baldurs390 Good Standing Member
i wanna do projectors in my fogs so bad... was it an easy install?
FRPPFSWERKSDDMMassiveTruBenz
Baldurs390 is offline
Old 10-16-2012, 08:36 PM   #20
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,266, Level 19
Points: 1,266, Level: 19 Points: 1,266, Level: 19 Points: 1,266, Level: 19
Level Up 66% Completed
FF Reputation: 1 popwarhomie Good Standing Member
Those blazers look great. I still need to do my fogs. Think im going to run Morimoto matchboxes with 3000k. Going to be sweet having 2 sets of Bi-xenon projectors. The high beams are going to be awesome!
2010 Focus SE coupe 5 speed
Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/Projector retrofit/LED tails/ Walled with 2 SQ HDC3 18s.
94 Lightning
A lot of mods.
popwarhomie is offline
