Using 4 Screws to Secure Focus Rear License Plate (WARNING) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-15-2012, 08:46 AM   #1
Tiger-Heli
Fan#: 12379
Points 904, Level 16
Points: 904, Level: 16 Points: 904, Level: 16 Points: 904, Level: 16
Level Up 4% Completed
Forum Activity 9%
Someone here recently posted that is was possible to remove the rubber spacers and use standard plastic nut retainers to secure the Focus rear license plate using 4 screws.
That is only PARTIALLY true (at least on a hatchback, not sure on a sedan).
The rubber spacers do pop out easily and Ford did use a standard square cutout for them. Any AFTERMARKET (I prefer Dorman, but Bell works also) THIN retainer will work just fine. However, if you try to use the OEM gray Ford retainers that are used for the upper screws, you will have major problems. The Ford fasteners protrude about 1-inch behind the panel and beyond 3/4-inch they will contact a structural reinforcement that is part of the hatch structure. Typically they will get stuck at this point and will be difficult to remove. They can't be used in any case without trimming them, which I wouldn't recommend. I ended up having to remove the hatch trim panel and the latch mechanism to get them back out. (Hatch handle covers pop off - two 9/32-inch head screws under each one, about a dozen retaining clips on the hatch trim, 3 T40-head screws on the latch.)
I was able to use the foam gaskets that came with the OEM retainers with the aftermarket ones, and I don't know where to get those separately, so except for time, it wasn't a total loss. Just trying to save others some unnecessary grief.
Tiger-Heli is online now
Old 10-15-2012, 12:11 PM   #2
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
I just went to AutoZone and got some square tag nut clips. Then went to Ace and got some short stainless screws. Worked like a charm. My new warped AZ tag was chaffing against the paint, so this was a way to stop that and plug the two extra holes in the hatch to keep water out.
AZfocus2012 is offline
Old 10-15-2012, 12:14 PM   #3
Tiger-Heli
Fan#: 12379
Forum Activity 9%
Correct - AutoZone nut clips work fine. Ford OEM ones do NOT.
Old 10-15-2012, 12:15 PM   #4
BrApple
BrApple's Avatar
Fan#: 95810
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
thats interesting. The dealer that I got the car from put some in at the bottom of the plate. However they are to long and do not sit flat. But the screw expands the plastic anyway so they are holding tight.
Might have to look at it again.
- 12 Focus SE - 5spd
- 2k Contour SVT - #2137
BrApple is offline
Old 10-15-2012, 12:22 PM   #5
Tiger-Heli
Fan#: 12379
Forum Activity 9%
Seems like what I ran into. The gray OEM ones will angle down away from the liftgate. You could probably get a screw to hold the plate to them, but it won't be correct.
The aftermarket fasteners work fine, though.
Old 10-15-2012, 04:21 PM   #6
BrApple
BrApple's Avatar
Fan#: 95810
iirc, the top two are gray and I know the bottom two are black.
BrApple is offline
Old 10-15-2012, 04:46 PM   #7
Touring05
Fan#: 96695
What I Drive: 2012 ISM SEL Hatchback
Points 251, Level 5
Points: 251, Level: 5 Points: 251, Level: 5 Points: 251, Level: 5
Level Up 2% Completed
FF Reputation: 2 Touring05 Good Standing Member
I took off the grey OEM ones from the top and the black rubber nipples from the bottom and replaced it all with this:http://www.google.com/url?source=img...Jo5fZoqZOip2wQ
It works great and the license plate is nice and secured with the weathertech frames I have
2012 OEM+ Ingot Silver Metallic Hatchback w/ Premium Package & Sunroof
Touring05 is online now
Old 10-15-2012, 05:08 PM   #8
AZfocus2012
Fan#: 92484
Those look just like the AutoZone one's except they are black.
Old 11-16-2012, 11:59 AM   #9
ArcticGabe
Fan#: 86046
What I Drive: 2013 SE Hatch MTX
FF Reputation: 1 ArcticGabe Good Standing Member
Awesome info! This is just what I was looking for. Thanks so much for posting this.
ArcticGabe is offline
