Headlamp washers don't work - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-15-2012, 07:42 AM   #1
amuhans
Fan#: 95649
What I Drive: 2003 Focus
FF Reputation: 1 amuhans Good Standing Member
Hello,
I own ford focus mk1 2003 1.8 tdci with orginal xenon headlamps and headlamp washers. I notices that guy who changed my clutch did forget to return reverse switch connector on it's place so I had issue with reverse light. I fixed it but another isuue is still apear. My headlamp washers doesn't work after replacing clutch. I didn't noticed this issue from begging so it was late for reclamation. Windscreen washers works perfectly. I assume there are two independent pumps not one attached to bottle for washing system (windscreen + headlamp). Is there chance that guy also forget something to re-attach or something else can be wrong? Please advice which points I have to check.
amuhans is offline
Old 10-15-2012, 10:31 PM   #2
mikeeshaq
Fan#: 72526
Points 626, Level 12
Level Up 52% Completed
From the USA
Headlight washers on a early Focus? Maybe I am blind , I have not notices any
mikeeshaq is offline
Old 10-16-2012, 02:21 AM   #3
amuhans
Fan#: 95649
We are talking about Europe mk1 focus. Yes it is supplied with headlamp washers.
amuhans is offline
Old 10-16-2012, 12:12 PM   #4
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
With headlamps on (switch set to on) and ingnition on (engine not running) , try using the washer, (holding it for like 10-15 seconds) and listen for the pumps sounding, the washer pump for the headlights should run for the first 3-6 seconds , making a lot more noise than the windscreen washer pump, chk this first, before we start looking into the wiring.
nilskje is offline
