Car dies when stopping - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Old 10-12-2012, 01:44 PM   #21
BigMuthatrknG
BigMuthatrknG's Avatar
Fan#: 102123
What I Drive: 2001 Pitch Black ZX3
Points 581, Level 11
Points: 581, Level: 11 Points: 581, Level: 11 Points: 581, Level: 11
Level Up 62% Completed
FF Reputation: 1 BigMuthatrknG Good Standing Member
well cleaned my battery terminal. that made starting it quicker but still having a battery light come on and a rough idle that causes it to stall out sometimes. i changed the plugs. there looked to be rust? on the nut part of the old plugs. going to change the coil pack and clean the MAF tomorrow.
[HOONIGAN]
Rally Rev #86
Originally Posted by 02fordsvt View Post
The MK1 hatch. It's all about that ass.
BigMuthatrknG is offline
Old 10-12-2012, 01:47 PM   #22
BigMuthatrknG
Fan#: 102123
correction I cleaned and tightened my neg terminal. I read somewhere that foci need a cadmium silver battery. could this be a problem.
[HOONIGAN]
Rally Rev #86
Old 10-12-2012, 09:43 PM   #23
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 133,840, Level 100
Points: 133,840, Level: 100 Points: 133,840, Level: 100 Points: 133,840, Level: 100
Buy-Sell-Trade Rating: (11)
No it doesn't need a special battery, have you checked the PCV hose yet?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 10-13-2012, 09:54 PM   #24
BigMuthatrknG
Fan#: 102123
I have had the alternator checked and checked the pcv hose. It didn't seem to be collapsed but i couldn't really tell. the ford mechanic seems to think its either a messed up MAF sensor or the cams weren't set right when whoever last changed the timing belt
Old 10-14-2012, 10:54 AM   #25
Points 27,399, Level 98
Points: 27,399, Level: 98 Points: 27,399, Level: 98 Points: 27,399, Level: 98
Level Up 5% Completed
Forum Activity 19%
Yeah, but I'd think that a timing problem would've been evident when you drove it away after the timing belt job. It's not something that will develop over time.
You can replace the PCV line with plastic elbows and line for about $10. You should also replace the PCV itself since it can become clogged and cause these problems without any evidence of issues on the hose.
Old 10-14-2012, 11:07 PM   #26
BigMuthatrknG
Fan#: 102123
Why would that have any bearing on the battery light that doesn't make sense. But to be sure which is the PCV Line? Is it at the top attached to the valve cover or down lower because the lower hose feels very strong but the one on top is kinda cheap feeling and has a mini air cone on the end of it. I did not do this the previous owner did. I believe the last time the T belt was changed was with the previous owner as well.
Old 10-19-2012, 03:38 PM   #27
BigMuthatrknG
Fan#: 102123
Just found the vac leak i feel stupid for not noticing. the EGR valve has a bolt on the bottom that had come loose and fallen down causing the Vac leak. the timing belt is still slapping the top of the timing cover every now and then and now I have discovered that the radiator fan is not coming on.
Old 10-22-2012, 01:32 AM   #28
BigMuthatrknG
Fan#: 102123
Fine tuned my timing today. battery light hasn't come on lately. Cooling fans are still acting up. may just be the plug not sure though
Old 10-25-2012, 02:31 AM   #29
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
ive had this issue happen several times , under different circumstances. it almost always does it for a while when i disconnect the battery to reset the ecu , and then sometimes it does it after gassing up at crappy stores. no idea , i just deal with it when it happens.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
