Fuel spill when pumping gas - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-08-2012, 09:21 PM   #1
Dark 007
Dark 007's Avatar
Fan#: 80502
What I Drive: 2001 marshall red LX
FF Reputation: 1 Dark 007 Good Standing Member
Recently when I pump gas, at about 3 gallons (I usually pump around 6 gallons) my gas tank does a "gagging reflex" like if It had a complete full tank. It only "gags" out just a small spill. At first I tought it was just a bad pump station, but when I switched from the usual station it still did it. If anything, my mpg seems to be just fine. Could it be signs of a bad fuel pump?!? or something else
Dark 007 is offline
Old 10-09-2012, 07:32 AM   #2
jdetzel
Fan#: 102548
Points 177, Level 3
Points: 177, Level: 3 Points: 177, Level: 3 Points: 177, Level: 3
Level Up 54% Completed
Are you saying that gasoline comes back out of the fuel filler neck? Like on to your hand or the ground or onto your car.
jdetzel is offline
Old 10-09-2012, 07:59 AM   #3
05focusST91
05focusST91's Avatar
Fan#: 83640
Points 2,857, Level 32
Points: 2,857, Level: 32 Points: 2,857, Level: 32 Points: 2,857, Level: 32
Level Up 72% Completed
It could be a clogged filler neck, if u have compressed air you can shoot air through and maybe free it up
Funtion>form.
FLOOR IT!
2005 focus ST (gone)
Still here!
05focusST91 is offline
Old 10-09-2012, 03:23 PM   #4
Dark 007
Dark 007's Avatar
Fan#: 80502
Yes! thank you, that's exactly what I tried to explain.
Posted via iPhone using FF Mobile
Dark 007 is offline
Old 10-09-2012, 03:31 PM   #5
Dark 007
Dark 007's Avatar
Fan#: 80502
That sounds like it could be the problem, but i'm interested on what could be clogging it. Dirt perhaps?!?... I shall try unclogging it with compressed air.
Dark 007 is offline
Old 10-09-2012, 04:46 PM   #6
jdetzel
Fan#: 102548
Points 177, Level 3
If you force compressed air in then you will be forcing flammable fuel vapor back out - I do not think that is a good idea.
When you add fuel air needs to escape from the tank. To do this there is a vent tube that usually runs alongside the filler pipe. I think either the filler pipe is kinked or the vent tube is blocked.
I would call a Ford dealer service department or a good independent repair shop, describe what is happening and ask if they have heard of it before.
jdetzel is offline
Old 10-09-2012, 06:50 PM   #7
05focusST91
Fan#: 83640
Usually spiderwebs
Funtion>form.
FLOOR IT!
Still here!
Old 10-10-2012, 04:05 PM   #8
Dark 007
Dark 007's Avatar
Fan#: 80502
Now that you mentioned it could probably be clogged, because my fuel compartment cap locking machenisim (the one attached to the car's body) is broken. With that said, the filler pipe DOES get exposed to dirt, snow, leafs and even "spider webs". Thanks! I'll pass on forcing compressed air. And I'll shall contact my local Ford dealer service department, and get a second opinion from my mechanic.
Dark 007 is offline
Old 10-10-2012, 04:50 PM   #9
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Points 4,699, Level 43
Level Up 75% Completed
There is a roll over valve in the tank to prevent fuel from spilling if you ever crashed and rolled your car. Maybe it is stuck, but it is probably debris as mentioned especially if you don't have a gas cap.
60k+ miles.
a_2000_se is offline
Old 10-10-2012, 09:29 PM   #10
Dark 007
Dark 007's Avatar
Fan#: 80502
Fortunately, I haven't rolled the car. But I'm hoping it is debris and nothing serious. I shall take it in for inspection as soon as I get the chance.
Dark 007 is offline
