Technical Difficulties - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-10-2012, 10:09 AM   #1
rheath011
Fan#: 104551
What I Drive: 2000 focus zts
FF Reputation: 1 rheath011 Good Standing Member
Before ANYONE FLAMES ME FOR BEING IN THE WRONG FORUM.
I realize this is not the coorect place to post this question.
I am jut hoping that the people here are a bit more technically advanced than in the general tech dicussions and I can finally put this issue to rest!!
Here goes
Blower motor does not work power on ground and positve cables
Ac swithch light will not come on
When I ground out the blower motor blower works ac kicks in and led on switch comes on everyhing seems to work properly
Just going through the system replaceing parts... I just don't know any other way to troubleshoot this issue
Right now I am trying to find the ac/clutch diode.. and I am not talking about D1 or D2 in the fusebox . The schematics show another diode
in the system and my deaership has actually been able to get me one ( which is more than they could do when I was replacing D2). I have traced the wires shown in the schematics but it still seems to be hiding from me.
So if any one could tell me where this diode is located or has successfully fixed the problem of having power on the ground on the blower motor please let me know how I an fix this !!!
This seems to be a fairly common problem on the focus. I have found several post on other BB's with other pople having the same issue but NO resolutions!!
SO if you can help PLEASE let us know!!!!!!
----- The first 49 years of my childhood have been real hard on me ------
rheath011 is offline
Old 10-10-2012, 04:26 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 33%
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat" to better help you.
zetecDon is offline
Old 10-10-2012, 04:43 PM   #3
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Points 4,699, Level 43
Level Up 75% Completed
If it's what I'm thinking you may be talking about - see if they put that on the resistor pack under the dash and behind the glove box. I seem to recall someone else having an issue with blower motor/switch/AC and it was an interesting fix. Maybe it will come to us.....
60k+ miles.
a_2000_se is offline
Old 10-10-2012, 05:28 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,689, Level 86
Points: 18,689, Level: 86 Points: 18,689, Level: 86 Points: 18,689, Level: 86
Level Up 68% Completed
Forum Activity 18%
C972 is where the connector for the diode is located.
But the diode is physically located in the BJB.
A most likely scenario is that the Heater Control Module is damaged. That is the black plastic part behind the controls on the dash.
If jumping power makes the blower motor spin, you just bypassed that switch. Being it and the blower motor resistor are both in line, both have to be suspect. If it's not the blower resistor it must be the control module.
iminhell is offline
Old 10-11-2012, 08:15 AM   #5
rheath011
Fan#: 104551
thank you but I already replaced the resistor pack with no effect.
I have since confirmed the old resistor was functioning
Thank you !!!
THe picture is a graet help!
I agree if there is a heater control module that is a more likely suspect!
Resistor pack is good but I was unaware of heater control module
THANK YOU!
My next step was to see if I could ground through the switch ( to get speed controls back) My guess is that is exactly what the heater control module does !!!
Thank you once again
the only thing I can find related to "heater control module" at my local part stores is called a heater control pigtail which appears to be nothing more than the connecter to the fan switch. is this what you werre talking about ??
sorry the sun just came up here.... went out to the care and I am pretty sure I found the part you are talking about . the wires that actually plug into the resistor correct ??
Old 10-11-2012, 01:37 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 18%
Quit shopping at a parts store.
Go to Ford and get the correct parts.
iminhell is offline
Old 10-12-2012, 10:35 AM   #7
FordService
FordService's Avatar
Points 3,388, Level 36
Level Up 26% Completed
Forum Activity 25%
Originally Posted by rheath011 View Post
...Blower motor does not work power on ground and positve cables
Just going through the system replaceing parts... I just don't know any other way to troubleshoot this issue...
Hi rheath011,
As you continue your parts hunt, you may have better luck contacting the parts department of your local Ford dealership or ordering parts yourself through http://www.fordparts.com. It's always wise to use Ford-approved parts when repairing your vehicle.
Good info, everyone. Group effort for the win!
Have a great weekend!
Crystal
FordService is offline
Old 10-12-2012, 12:19 PM   #8
rheath011
Fan#: 104551
Win?????
The operation was a success but the patient died ????
I have still not resolved this issue
Old 10-12-2012, 04:02 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 18%
Did you buy and replace the control module like I said?
iminhell is offline
Old 10-16-2012, 02:34 PM   #10
rheath011
Fan#: 104551
yes I did
still no joy in mudville lol
