Suspension fix - no more front end clunk - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-09-2012, 02:29 PM   #51
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Level Up 82% Completed
Forum Activity 12%
Eh, nvm.
PratoN is offline
Old 10-15-2012, 09:15 PM   #52
12FOCUS S
Fan#: 98622
What I Drive: '13 FOCUS ST/'12 Mustang GT BBP
FF Reputation: 1 12FOCUS S Good Standing Member
Talking
http://www.ajusa.com/KONI-Sport-Shoc...7ad4q8fd8.html
considering this set of shocks......not sure about springs. Yellow Konis on my 2012 Mustang with Steeda Sports.
Paid 470.00 for 4 Koni for a 2002 SVTF that I owned. Not a bad increase in price 1 decade later......
http://www.ajusa.com/Bilstein-24-113...er-ab0404.html monotube B8's
12FOCUS S is offline
Old 10-16-2012, 08:25 AM   #53
slowmazda3
Fan#: 58220
What I Drive: a rental
Points 683, Level 13
Points: 683, Level: 13 Points: 683, Level: 13 Points: 683, Level: 13
Level Up 66% Completed
FF Reputation: 0 slowmazda3 Newbie
The Konis will require some "modification" for fitment and will raise the ride height of the car. I cam currently looking to pick up these:
http://www.european-parts.net/catalo...oducts_id/1357
The rears bilsteins will bolt right in without issue.
I bought a mazda and all I got was some crappy motor mounts and wheelspin.
slowmazda3 is offline
Old 10-16-2012, 08:51 AM   #54
Bwhit1
Bwhit1's Avatar
Fan#: 95170
What I Drive: 03 svt focus
FF Reputation: 1 Bwhit1 Good Standing Member
The reason why the struts blow out so early is because when they ship the cars they are on the truck with the suspension bottomed out because of how they are hooked. When they release the car it releases fast which then makes the car spring up quickly. I work at ford and its not just the focus its the escapes, fusions, and Taurus that have the problem.
Bwhit1 is offline
Old 10-16-2012, 09:14 AM   #55
slowmazda3
Fan#: 58220
FYI, its not the rebound that blows the shock, but the compressive force when the suspension is already fully loaded down (hooked). Every bump that train/semi takes compresses the suspension with the full load on the shock already.
This is why many manufacturers ship with spring blocks that are to be removed at dealer prep.
Old 01-12-2014, 12:23 PM   #56
fenway1912
Fan#: 116879
What I Drive: 2013 Focus SE
Points 10,761, Level 68
Points: 10,761, Level: 68 Points: 10,761, Level: 68 Points: 10,761, Level: 68
Level Up 78% Completed
FF Reputation: 2 fenway1912 Good Standing Member
TireRack sells Bilstein Sports now, which as far as I know are supposed to be shorter length Bilstein HDs?
fenway1912 is online now
Old 01-12-2014, 01:07 PM   #57
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,360, Level 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
Level Up 40% Completed
Forum Activity 15%
FF Reputation: 6 CunFFS13 Good Standing Member
Make it a sticky
CunFFS13 is offline
Old 01-12-2014, 01:55 PM   #58
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
I believe that's correct. According to Bilstein, the Sports (b8 ) are designed to go on vehicles that have been lowered 30 to 50mm.
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 01-12-2014, 04:10 PM   #59
wavsine
wavsine's Avatar
Fan#: 118470
What I Drive: 2013 Focus SE Oxford White Hatch 5m
Points 19,013, Level 87
Points: 19,013, Level: 87 Points: 19,013, Level: 87 Points: 19,013, Level: 87
Level Up 33% Completed
Forum Activity 16%
FF Reputation: 16 wavsine Great Standing Member
FYI, this is a necropost. There is a much simpler and less expensive way to get rid of the front end clunk now. The fix was originally discovered by forum member Dysan911 and Ford finally released a TSB to address the issue:
TSB 13-9-9 CLUNK/RATTLE NOISE FROM FRONT END DURING PARKING MANEUVERS AND/OR OVER ROUGH SURFACES AT LOW SPEEDS BETWEEN 8-32 KM/H (5-20 MPH)
Use a Motorcraft FL-400S filter to increase filtration media and oil quantity. (Drop in for FL-910S)
Synthetic oil in GDI engines
www.focusfanatics.com/forum/showthread.php?t=324396
wavsine is offline
