Blows heat when set to cool air - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-09-2012, 11:09 AM   #11
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
Originally Posted by riparke View Post
Did some test this past weekend, 4hr drive at 70 mph on I 29, 50 degrees outside, overcast (no sunshine, so no heating of dash), control set to cold as far as it will go without triggering AC, air directed to floor.
Results 68 to 70 degrees at drivers floor vent (18 to 20 above outside temp)
Dealer said this is normal, contacted Ford and did a AC temp check for this against another Focus. When I had dropped the car off in the morning they said they saw the problem, but by end of day, no problem. Told me they checked the blend door by eyeball with a flashlight. I looked under the dash from both side and can't see sh_t of any flap or door. I have the manual temp controls and think I'm being told bullsh_t.
Wait wait wait... you're adjusting the dial as far as it will go WITHOUT pressing AC on...?
What are we missing here? Just having the fans on without turning on the AC isn't going to result in cold air... I don't understand your issue here.
Sonic Crew #28
feta_mgp is offline
Old 10-09-2012, 11:19 AM   #12
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
I think he's expecting outside vent air to be closer to ambient than +20 above.
Hatch Nation #90
TboneZX3 is offline
Old 10-09-2012, 03:52 PM   #13
riparke
Fan#: 95781
What I Drive: 2012,red,se,hatch,manual,sport pkg
Points 419, Level 8
Points: 419, Level: 8 Points: 419, Level: 8 Points: 419, Level: 8
Level Up 38% Completed
FF Reputation: 1 riparke Good Standing Member
Yes I don't want heat, just outside air closer to ambient. The dealer did the AC test, when I said fresh air.
riparke is offline
Old 10-09-2012, 03:59 PM   #14
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Turning the AC on without recirculating IS pulling in fresh air, it's just cooling it on the way since that air passes over/around the engine, which obviously is much hotter than ambient.
Expecting air blown in from outside to be at ambient temps is a bit unrealistic, I think, keeping in mind the whole engine thing.
At the end of all this... my question is... why not just use the AC, or better yet if ambient temps are such a concern, open the windows...
Sonic Crew #28
feta_mgp is offline
Old 10-09-2012, 04:07 PM   #15
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,007, Level 33
Points: 3,007, Level: 33 Points: 3,007, Level: 33 Points: 3,007, Level: 33
Level Up 72% Completed
Forum Activity 10%
eh... I dunno... I'll check this out on my car on the ride home. I have dual climate controls, but I think my legs could get pretty cold if I put the dials down to "LO" but keep the AC off.
Not that I ever would. I like my legs and hands warm, but my face cold. It's tough to manage. #diva
PratoN is offline
Old 10-09-2012, 07:49 PM   #16
riparke
Fan#: 95781
Points 419, Level 8
The air does not blow over and around the engine, It is sucked in at the cowl ( base of windshield) with a rubber gasket to seal it from the engine, open your hood and look. When it's 50 degrees outside on the hiway at 70 mph, I don't want to use AC or open the windows. Every car I have owned (I'm 64) does not heat air on cool.
riparke is offline
Old 10-09-2012, 07:54 PM   #17
Points 10,047, Level 66
Points: 10,047, Level: 66 Points: 10,047, Level: 66 Points: 10,047, Level: 66
Level Up 99% Completed
Forum Activity 24%
Dual zone automatic climate control set to 66F on auto with the a/c switched off, ambient temperature according to the car outside was 63F, measured 63-65F at the left of center vent.
suss6052 is online now
Old 10-10-2012, 04:10 PM   #18
riparke
Fan#: 95781
Points 419, Level 8
Thanks suss6052, I have the manual controls. would appreciate others measuring since my dealer said this is normal.
riparke is offline
Old 10-10-2012, 04:19 PM   #19
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Ambient air was 61 degrees here today, and the outside air flowing through my vents (no A/C) was cool. There's no way that air was anywhere near 80 degrees.
I have manual controls also. I'll try to get a temp measurement for you.
Hatch Nation #90
TboneZX3 is offline
Old 10-10-2012, 04:39 PM   #20
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 10%
Dual climate here, put the temp on LO and to the footwell. AC off, it was about 45 degrees this morning and the air coming from the vents was burrburr.
PratoN is offline
