Where is the best Grounding spot in hatches? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-01-2012, 08:34 PM   #1
mitchv
Fan#: 79720
What I Drive: 2003 blue zx3
I drive a 2003 zx3 and was wondering where the best grounding spot is in our hatches. Has anyone actually used a DMM and tested it?
mitchv is offline
Old 10-01-2012, 11:37 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,797, Level 54
Points: 6,797, Level: 54 Points: 6,797, Level: 54 Points: 6,797, Level: 54
Level Up 24% Completed
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
Buy-Sell-Trade Rating: (23)
I drilled a hole on the spare tire bracket. But, then again, I am only running 700 watts in the current form. Many use the rear seat belt mount.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 10-01-2012, 11:41 PM   #3
mitchv
Fan#: 79720
Hmm looks like ill have to stop being lazy and run a temporary wire, im grounded to where the stock sub bracket bolted into but im looking for something better. Pushing 1500 watts now
mitchv is offline
Old 10-02-2012, 12:05 AM   #4
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 46%
Are you getting any dimming?
What is the meter reading?
Hatch Nation #140
freemind is offline
Old 10-02-2012, 01:49 PM   #5
mitchv
Fan#: 79720
Im getting tons of dimming I dont have a volt meter in the car and Im afraid to have it parked playing because I dont want to drop belowe 12volts and hurt my amps. But yes a ton of dimming is occuring, thinking I might upgrade big 3 to 4/0 OFC welding wire.
mitchv is offline
Old 10-02-2012, 03:09 PM   #6
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 46%
Ygpm
Hatch Nation #140
freemind is offline
Old 10-07-2012, 10:12 AM   #7
Jeffrosilver07
Jeffrosilver07's Avatar
Fan#: 104592
What I Drive: 2007 Silver Focus SE
Points 527, Level 10
Points: 527, Level: 10 Points: 527, Level: 10 Points: 527, Level: 10
Level Up 54% Completed
FF Reputation: 3 Jeffrosilver07 Good Standing Member
I had an 02 SVT and now have a 07 SE, I used the same grounding bolt in both cars and had very good success with it. I used an impact gun to remove the back seat back bolts and then a dremel tool to get rid of the paint. Sandwiched the ground between the metal floor and the seat back and put the bolt back in. I have a 0 gauge ground so the ring terminal is pretty big and was able to fit around the bolt. Neither cars had/have any noise issues from placing the ground in that location. Hope this helps.
Jeffrosilver07 is offline
Old 10-07-2012, 10:20 AM   #8
02Zetechse
02Zetechse's Avatar
Fan#: 65832
rear seat bracket or shock bolt, I currently just rtun a negative to the front tho
02Zetechse is offline
Old 10-08-2012, 04:29 AM   #9
thingsidont
Fan#: 90749
What I Drive: 2001 sterling grey ZX3
Points 474, Level 9
Points: 474, Level: 9 Points: 474, Level: 9 Points: 474, Level: 9
Level Up 48% Completed
FF Reputation: 1 thingsidont Good Standing Member
any luck on fixing your dimming cause im running about 1200w and ive done the big3 and i still got dimming
thingsidont is online now
Old 10-08-2012, 04:50 PM   #10
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 46%
Class D or, A/B amps?
What is your voltage(with the car running and the system off)at the battery?
Now check it with the system on.
Post the variance.
Hatch Nation #140
freemind is offline
