Think I figured out the shuddering when starting from a stop...can't believe it - Page 18 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-08-2012, 12:39 PM   #171
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
Originally Posted by gkirk View Post
I've been trying the traction control on and off for a few days now. I've noticed that the car seems to do better in a corner under acceleration. I still need to test more.
But the throttle seems more responsive without the traction turned on.
Might be wishful thinking tho. :\
I too have noticed both of the above. Where I used to get "dead" spots in acceleration seem much more responsive with TC off.
Sonic Crew #28
feta_mgp is offline
Old 10-08-2012, 01:18 PM   #172
Dysan911
Fan#: 95746
I realize that you're upset (because I am too) but the 11-12-13 TSB is for bad seals on the transmission that leak onto the clutches. That's what is causing our shuddering and chattering. If you do have the issue (and I'm fairly certain you do), the TSB calls for replacement seals (three, in fact), dual clutch assembly kits, and a few other random nuts, bolts, and snap rings.
Basically, if you had the seal leak, you were getting new clutches anyway. But good luck on getting the TSB done! My appointment with the dealership is at 1pm tomorrow, so I'll need some luck too.
I hope you guys with these issues are fortunate enough to get approved for the repairs regarding the 11-12-13 TSB. My car had that TSB completed a few hundred miles ago and let me tell you what a WORLD of difference it makes!. (Even better with Trac OFF) Yeah there's still the occasion where DCT will have a glitch like in 90 degree right/left turns which I believe is only ever going to be resolved in yet another Flash update. Performance wise my car has never felt as strong as it does now. Prior to the repair my gas mileage was climbing to a little over 31mpg average and then when the transmission started making all that noise and I found evidence of a leak I noticed my gas mileage was dropping. It got down to 28mpg average just prior to their repairing the car. I'm nearing 32mpg now and climbing steadily.
The biggest noticeable difference is on the highway. If I floored it from 70 or above. The car had NO Power whatsoever to barely accelerate and pass anyone. The RPM's would jump up but acceleration was weak at best.
OMG Not anymore!. Certainly not an ST acceleration but pretty damn impressive now.
Anytime I floor it, the car pulls HARD to redline, no more surging. I do try to baby it though because I'm so scared that I'm going to burn up the clutch and be right back to where the issues started but with any luck the TSB repairs are going to prevent any oil getting on my clutches and they'll be more than capable of holding the power every-time all the time.
All this to say that I can NOW finally enjoy the car so much more and for those feeling like these odd quirky embarrassing shifts and sounds are just normal. They are NOT!. Don't give up on pursuing this with your dealer or find one that is willing to hear you out and confirm your clutches aren't compromised in some way. There may not be very much oil on the outside of the casing that you can see but I bet if there's a little leak on the inside that it's sprayed everywhere internally.
Dysan911 is offline
Old 10-08-2012, 03:13 PM   #173
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,089, Level 34
Points: 3,089, Level: 34 Points: 3,089, Level: 34 Points: 3,089, Level: 34
Level Up 26% Completed
It's taking a lot out of me to not curse right now. The dealership kept me waiting in the waiting room for an hour, when he finally came back he said they test drove it (without me, despite my request) and all of their diagnostics came back as normal.
This is my most convenient dealership, but apparently also the most incompetent. I'm sick of having to request time off for this and get absolutely nothing accomplished.
EDIT: I'll be damned if I have to buy a new clutch in 1 year for a car that I don't even have the ABILITY to drop the clutch, chirp gears, burn out, etc.
PratoN is online now
Old 10-08-2012, 03:16 PM   #174
Dysan911
Fan#: 95746
Prato,
Check your PM's bro.
Dysan911 is offline
Old 10-08-2012, 03:58 PM   #175
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
Exactly. I'm dropping mine off tonight to get the TSB completed, but truthfully I'm not sure if they'll even do it. They've refused to even look into it before stating, "It's how Ford says the car should operate". I'm hoping listing the exact TSB # will do the trick.
I'm going to a Subaru dealership today to check out my options.
hotleadsingerguy is offline
Old 10-09-2012, 01:39 AM   #176
tigertiger
Fan#: 85787
What I Drive: 2004 green ranger; 2012 Focus SEL
FF Reputation: 1 tigertiger Good Standing Member
I can't imagine why a dealership would not apply a TSB when a customer states an issue clearly related to the TSB. What do they think they are gaining? What does it cost them?
There are days when I wish I would have bought a Subaru.
Hope all goes well with the repairs to your Focus.
tigertiger is offline
Old 10-09-2012, 08:57 AM   #177
gkirk
Fan#: 91903
What I Drive: 2012 C.Red Focus SE Sport Package
Points 391, Level 7
Points: 391, Level: 7 Points: 391, Level: 7 Points: 391, Level: 7
Level Up 82% Completed
FF Reputation: 3 gkirk Good Standing Member
When I brought my car in for the grinding/reflash, they said they charged ford 67 bucks for the work. My guess is that if they're busy, they make less money on warranty work.
gkirk is offline
Old 10-09-2012, 09:54 AM   #178
FordService
FordService's Avatar
Points 3,490, Level 36
Points: 3,490, Level: 36 Points: 3,490, Level: 36 Points: 3,490, Level: 36
Level Up 94% Completed
Forum Activity 27%
Good morning everyone!
Just a reminder that I'm here to help. I'm gathering VINs from people who are happy with turning Traction Control off as it relates to their DCT's performance, so if you haven't already, please send me a PM with your VIN and whether or not you've had the 12B37 TSB applied to your vehicle.
If you're experiencing any other issues, I'm happy to jump in and assist with those as well; send me a PM and I'll get to work.
Thanks!
Crystal
FordService is online now
Old 10-09-2012, 11:04 AM   #179
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Dealerships are actually audited on TSB/Warranty related repair work. If they willy nilly decide to replace a part that's functioning perfectly on a customer's vehicle and then the audit shows that the replaced part actually was in good working order, the dealership foots the bill and doesn't get credit for the work. That's how I've come to understand it.
That said, almost everyone in this thread should have sufficient evidence to argue in their favor to get this TSB applied, afterall, we're all exhibiting similar issues, some worse than others, but similar nonetheless, this is NOT an isolated incident.
Sonic Crew #28
feta_mgp is offline
Old 10-09-2012, 01:33 PM   #180
hotleadsingerguy
Fan#: 86687
^^ This. The dealerships are denying TSB coverage on a lot of it because of the vague terms that Ford uses. "Shudder" could mean anything from a barely-noticeable vibration to a violent shake. Using terms like that without any other descriptive means they're going to be hesitant to replace things on the off-chance that it won't be covered and they'll have to pay for it.
And that's why the dealerships have denied doing work on my car 5+ times.
