Rear Alignment - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-07-2012, 10:11 PM   #1
2012_Focus_
Fan#: 98386
What I Drive: 2012 Black Titanium
FF Reputation: 1 2012_Focus_ Good Standing Member
Rear Alignment
Hi, I bought 2 new rear tires and I had my alignment done by a very good alignment place, but I dont know if they have ever done a new focus? The place uses hand tools (not laser) and it took them a long time to adjust the rear. He told me that camber is not adjustable, which from what I read is true, but I feel like my car sways and pulls the curve of the road so much more then before the alignment.. My steering wheel isnt 100% straight but I think they just touched the socket down there just to charge$ me for it (I dont think it was even off).. looking at my rear tires I can tell the camber is off and from the naked eye it looks like my toe is also off..
Does anyone have the 2012 alignment specs?
Also does anyone know if the dealerships drive over thing "alignment check" is a actuate specs.. Cause I spent alot of money and dont know if I want a refund or let them check it n fix if needed.. Thanks Jay
2012_Focus_ is offline
Old 10-07-2012, 10:18 PM   #2
Power Surge
Fan#: 55878
What I Drive: 2012 Race Red SE 5-door
FF Reputation: 1 Power Surge Good Standing Member
What part of FL are you in?
The new Focus is no different than the previous models, chassis wise. Everything adjusts the same.
Sal
2012 Race Red 5-door SE, 18" Ti wheels, Ti headlights/fog bezels, 20% tint, debadged trunk
2002 Sonic Blue SVT - supercharged (sold)
2008 Vista Blue SE (gone)
Power Surge is offline
Old 10-07-2012, 10:38 PM   #3
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
Buying two new tires shouldn't really have warranted an alignment, as long as the tires were balanced properly if the car was aligned well before, it should have been fine. I'd definitely see what the heck is up, I wouldn't even trust a place that did it by hand without an alignment rack with a laser system.
Sonic Crew #28
feta_mgp is offline
Old 10-07-2012, 11:42 PM   #4
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,753, Level 76
Points: 13,753, Level: 76 Points: 13,753, Level: 76 Points: 13,753, Level: 76
Level Up 26% Completed
Forum Activity 16%
Buy-Sell-Trade Rating: (18)
How many miles were on those tires? Also did you rotate them at a regular interval?
SkyPilot is offline
Old 10-08-2012, 07:03 AM   #5
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,305, Level 29
Points: 2,305, Level: 29 Points: 2,305, Level: 29 Points: 2,305, Level: 29
Level Up 4% Completed
Just wondering how you're judging the toe is off with the naked eye. The camber you're seeing is probably the negative camber you should have in the rear. Your camber shouldn't be 0. The only reason you should need an alignment in the rear this early is if you've completely beat the hell out of your car on extremely rough roads or ebrake drifted your rear end in to a curb. Also, why are you only changing the rear tires? Do you not rotate then stick the rears on the front once the front wears down?
Last edited by BetaDnB; 10-08-2012 at 10:15 AM. Reason: grammatically incorrect use of the word "you're"
BetaDnB is offline
Old 10-08-2012, 10:09 AM   #6
jdetzel
Fan#: 102548
Points 173, Level 3
Level Up 46% Completed
You had a 4 wheel alignment done right? Which is what one should do with a vehicle like ours that has 4 wheel independent suspension. You replaced 2 tires because they were worn and you put the new ones on the rear right? Which is what is recommended on a vehicle like ours that has front wheel drive. All of that all sounds about right.
The only thing is that the alignment was not done on some sort of measuring system, if I understood you correctly. That does not sound right. It seems like a very good alignment place would have a very good alignment system.
Do you think maybe you feel the new tires with brand new tread catching the irregularities in the road surface because they are brand new and have new tread?
jdetzel is offline
Old 10-08-2012, 10:17 AM   #7
2012_Focus_
Fan#: 98386
thank you for being positive, I have 25k Miles and replaced 2 tires cause of money.. from what I hear on here and others the stock pilot 3 dont get many miles out of them so I went with Michelin MXM4.. The place that did the alignment is Weber Wheel Alignment in Palm Beach FL. Been in business for years, never had a problem with my trucks i've brought there.. This was my first alignment since i've owned the car.
Old 10-08-2012, 10:20 AM   #8
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Huh?
Hatch Nation #90
TboneZX3 is offline
Old 10-08-2012, 10:24 AM   #9
2012_Focus_
Fan#: 98386
Originally Posted by TboneZX3 View Post
Huh?
When you pull into the service bay the dealer has a platform you drive on and it tells you if your alignment is off
Old 10-08-2012, 10:50 AM   #10
jdetzel
Fan#: 102548
Points 173, Level 3
25K sounds about right for those tires. I have the same and will be happy to get that from mine. I am probably going to look at some other brands, Yokohama makes a 40k tire for our car and I have had very good service from them in the past.
If this is a place you know and trust then you are probably good. But still makes me wonder about not using an alignment system. Have them recheck it.
jdetzel is offline
