#11 | ||||
2005 ZX4 ST, Stealth CAI (so far) Used to have, and will always regret selling, 1970 Mach 1. "Everday is a good day, just try missing one." "As soon as we're born we start dying, so you might as well have a good time." |
#12 | ||||
#13 | ||||
My 00 se is doing the same. I replaced control arms,end links,tierods only to find it was the strut mount! My car has 109,000 on it. The rubber around the mount is cracked and showing age.
#14 | ||||
If dogbone then you will catch the clunk on and off power going straight ahead too.
Turning only at full lock says strut mount or balljoint. Sometimes you swear the joint is tight but you cannot replicate the exact forces on a ton and a half car with a crowbar. BTDT. Not CV, if clunking there is no way you won't catch it going straight or close to straight too. The wear in CVs is mostly in the straight ahead position, once you vary from that even a little you would run into the clunk long before you get to full lock steering. In CV the clunk is the ball snapping from a worn slot to the relatively unused new part of slot towards the ends. There is an edge that develops there from two arguing slot patterns, the ball snaps across it. The edge should generally show around a half turn or so, not full lock only. |
