Odd Oil issue - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-05-2012, 07:30 PM   #11
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007 Focus
ok, so I am a bit confused then, the Valve cover vent on top rear of motor is the PVC you people are mentioning? I thought thought the PVC was the device on the front lower passenger side that has a Valve on it that can be made to be cut to back off the system.. I assumed doing just one half was ok for now, so I need to revent to the intake would kill the oil light? until I do the PVC valve delete...??
when I posted "like this one" the picture never showed up... so I will repost Picture of what I put on the Valve cover
VEGAS is offline
Old 10-06-2012, 09:34 AM   #12
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
Buy-Sell-Trade Rating: (13)
Air needs to "flow" through the engine for the PCV valve (located behind the intake manifold) to work. If I'm understanding your setup right the valve cover is vented but the PCV valve is stuck closed because there is no vacuum to open it.
Here are some options:
1a)Run a hose from the valve cover to the ground
1b)Pull the intake manifold, pop out the PCV valve, cut the bottom off carefully, remove guts, re-install valve body (its now open all the time because you removed the guts) and run hose to ground, close off intake manifold port (Sporadic did this on his first turbo build, pictures in that thread)
Or you could setup a catch can: (Must be vented!)
2a) Run hose from valve cover to catch can
2b) Gut the PCV valve (same as above), run hose to catch can
2c) Throw that little filter on the top of the catch can so air can escape and the nasty stuff stays in the catch can
I think that would help your oil issues, plus the balance shaft delete for more oil capacity.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
D23 Crew: #07
Jgrove998 is offline
Old 10-06-2012, 02:41 PM   #13
06focuskid
Fan#: 42764
What I Drive: SILVER 06 zx3 ses 5spd FORD GFX PKG
FF Reputation: 41 06focuskid Great Standing Member
I would still watch the pump, Usually the light is on due to lack of oil pressure. You never know with man made prducts lol.
JUST SAY NO TO RICE!
06focuskid is offline
Old 10-06-2012, 02:59 PM   #14
VEGAS
VEGAS's Avatar
Fan#: 75680
Well I have a catch can.. just didn't install it yet. Dunno where to bolt it, the PVC valve behind the intake I have never touched and was working last I knew properly. But I planned to gut it per the directions on the PVC Delete thread..
Just filtered right now on valve cover so it sounds like ther eis a flow/vent, didnt plug anything.
VEGAS is offline
Old 10-06-2012, 02:59 PM   #15
VEGAS
VEGAS's Avatar
Fan#: 75680
Is there a Upgraded Pump available?
VEGAS is offline
Old 10-06-2012, 03:03 PM   #16
06focuskid
Fan#: 42764
I'm not sure guess you could google it lol
Old 10-08-2012, 01:43 PM   #17
VEGAS
VEGAS's Avatar
Fan#: 75680
Cosworth High Volume Oil Pump Ford Duratec / Mazda MZR 2.0L / 2.3L 01-11
$269
http://www.ebay.com/itm/Cosworth-Hig...sories&vxp=mtr
wonder if its worth it..
also this is a good writeup
http://duratec.wikispaces.com/modification-BSD
VEGAS is offline
Old 10-09-2012, 09:50 AM   #18
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Isn't it a mostly stock engine? Because the oil pump probably is a waste of time and effort. If you are getting low oil pressure, you probably are over-heating the oil. Switch to a synthetic 5w30, or install a cooler.
These engines tend to have low pressure at idle.
Egz is offline
Old 10-09-2012, 03:16 PM   #19
VEGAS
VEGAS's Avatar
Fan#: 75680
stock as in what, cams and valves, yes, but I have it at 6000 rpm most of the time. overheating I don't think so.. it is running motorcraft synthetic blend 5/20. but will be swapping back to Royal Purple 5/20 - if the tolorence levels were that of a 50k mile motor I might consider 30 weight, but its less then 3k miles. it would just add more undo pressure. I will be doing more then the CAI and header soon, going with cam, head and intake soon.. Doing everything shy of turbo. Currently at around 185hp
VEGAS is offline
Old 10-10-2012, 10:02 AM   #20
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Still, I think you are better off switching to a full synthetic at a thicker weight, and adding an oil cooler. I wouldn't worry about the pump unless you are about to tear apart the engine again, and even then, probably would not have the same effect as switching to a better thicker oil.
What are you doing at 6,000 most of the time? Please tell me this is a dedicated track-only car.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
