Idle vibration - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-05-2012, 08:26 PM   #1
Michaelc1220
Michaelc1220's Avatar
Fan#: 93834
What I Drive: 2012 Grey Focus SE hatchback Sport
FF Reputation: 2 Michaelc1220 Good Standing Member
Idle vibration
I saw a thread for this from 2011 but they didn't seem to know what exactly was causing it. When im sitting at a light with my foot on the break, occasionally there is a noticeable vibration. You can feel this from both the drivers and passenger side. It isn't too extreme but it was enough for two people to ask me what it is. Does anyone else experience this? My car has about 2200 miles on it. Thanks!!
Michaelc1220 is offline
Old 10-05-2012, 08:45 PM   #2
blank102
blank102's Avatar
Fan#: 96549
What I Drive: 2012 Sterling Grey SE HB
Points 2,639, Level 31
Points: 2,639, Level: 31 Points: 2,639, Level: 31 Points: 2,639, Level: 31
Level Up 26% Completed
FF Reputation: 1 blank102 Good Standing Member
I think it has to do with the direct injection.
blank102 is offline
Old 10-05-2012, 08:56 PM   #3
Rememo
Rememo's Avatar
Fan#: 95534
What I Drive: Was 2012 Focus. Now 2013 Impreza.
FF Reputation: 3 Rememo Good Standing Member
I've seen some posts fly by about bad motor mounts. That could cause vibes at idle.
Rememo is offline
Old 10-05-2012, 09:10 PM   #4
Michaelc1220
Fan#: 93834
Ive seen people saying not to replace the motor mounts and to clean some part under the motor but im not exactly sure where.. and the motor mounts should not need to be replaced after 2 months, that would be an incredibly short live span IMO
Old 10-05-2012, 09:21 PM   #5
Points 10,052, Level 67
Points: 10,052, Level: 67 Points: 10,052, Level: 67 Points: 10,052, Level: 67
Level Up 1% Completed
Forum Activity 23%
It wouldn't be that the mount was bad that some of the people want to change at least one of them, but that's the rear motor mount (RMM) or power train roll restrictor. That one allows the engine to tilt under load and absorb some of the slack in the power train, but too much slack leads to a disconnected driving experience. The stock mount is mostly made of rubber there where as the Mazda MazdaSpeed 3 rear mount is much more solid. Although that might nominally increase engine vibration felt in the cabin, it can help tighten up the roll of the power train allowing for less power to be wasted in this fashion. But its not likely to show up on a dynomometer.
suss6052 is online now
Old 10-05-2012, 09:45 PM   #6
SportyChick
Fan#: 104205
What I Drive: 2012 FocusTitanium Hatchback - sold
FF Reputation: 1 SportyChick Good Standing Member
This was one of the first things I noticed when I picked up my "new" used Focus a couple of weeks ago (I never noticed it on the test drive though). I would be sitting at the lights with my foot on the brake and the car would be vibrating during idle.
I took my car in to a Ford dealership this past Wednesday and told them about it and they fixed it. The previous owner of the car would have received (so I'm told) notification for 2 recalls, one being the sync and the second being reprogramming the PCM, TCM and ABS module. This second recall is what fixed the shaking car during idle and it in fact did fix mine, recall 12B37B for your reference. It may fix your issue, it may not but it's worth a shot.
[IMG][/IMG]
SportyChick is offline
Old 10-05-2012, 09:53 PM   #7
SportyChick
Fan#: 104205
I should also mention that since the applying the 127B37B, I now experience this:
http://www.focusfanatics.com/forum/s...298984&page=11
So it's a trade off, shaking car at idle or the shudder when you gas from a stop.
Old 10-05-2012, 09:55 PM   #8
Forum Activity 23%
[IMG][/IMG]
12B37 focused more on the traction control/abs/ powertrain and transmission control modules and strategies. It however did not fix the vibration at idle as it can and will fade in and out of the cabin depending on fuel quality, or just the general mood of the engine it seems. Direct injected engines are also running at higher compression closer to that of a diesel and this might magnify the four cylinder shake at idle. Sometimes its smooth, other times less so. Although my car was built in a date range beyond the effect of 12B37.
Old 10-05-2012, 09:56 PM   #9
Michaelc1220
Fan#: 93834
[IMG][/IMG]
Ill have to give the dealer a call tomorrow and ask if mine had the recall fixed. I bought it new on July 23rd so im not sure when that recall was released but its definitely worth a try. Do you know if I have to take it to the dealer I bought it from? or can I take it to the nearest Ford dealer.
Old 10-05-2012, 10:06 PM   #10
SportyChick
Fan#: 104205
Well I bought my Focus from a Honda dealership (I know it makes no sense) and made an appointment with the closest Ford dealership to my work. They took it in with no questions asked and ran the recalls. I did explain to them I wasn't the original owner and wouldn't have received notification of the recalls and they were fine with that as the car is still under warranty and transferrable.
suss6052, I can't begin to understand the exact mechanics of an engine and its behaviour but it did seem to help. I will make sure to keep close attention to the scenerios you described to see if I will experience the shaking again.
