Think I figured out the shuddering when starting from a stop...can't believe it - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-04-2012, 08:56 AM   #71
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Points 7,361, Level 57
Points: 7,361, Level: 57 Points: 7,361, Level: 57 Points: 7,361, Level: 57
Level Up 6% Completed
Forum Activity 11%
Originally Posted by hotleadsingerguy View Post
Well, drove home with it off and drove back to work with it off today...not one instance of shuddering. There's a *tiny* bit of clutch slip on takeoff, but that I would expect (same as any manual car)...and it's *GREATLY* reduced from when I have the TCS enabled......
This is good info but I don't think it explains for a lot of folks, including me a while back, why the shuddering starts happening only after 20 mins. or so of driving, or coming off an expressway after a longish trip. In other words, when the tranny is hot. I've seen several of the shuddering compainers say that it only starts after driving for a while.
Nor does it explain why my shuddering completely went away on its own. Unless the TCS logic also 'learns' and adjusts over time. So it may be an answer for some, not for all.
kam327 is online now
Old 10-04-2012, 08:57 AM   #72
dan50
Fan#: 91789
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
I thought traction control systems compared the rotational speed of the drive wheels, not torque, to identify slippage. It would be great if the TCS was the reason for our maladies but I can't quite get clear in my mind why it would be so. It makes sense for those who complain about odd behavior in a 90 degree turn (as drive wheel speeds would be different), but a straight-ahead start?
On the other hand, while my transmission behaves acceptably, to me it feels like the timing retards under low-speed acceleration, resulting in poor throttle response and a surging sensation. As traction control systems can use brakes, throttle and timing changes to deal with a spinning wheel, maybe this is really the cause. I'll give it a try later today.
dan50 is offline
Old 10-04-2012, 09:14 AM   #73
chum567
Fan#: 86507
What I Drive: 2012 Sterling Gray Focus SEL
FF Reputation: 1 chum567 Good Standing Member
Well tried it and it seemed slightly better but not much. I highly doubt I'll turn it off every single time I crank it cause that gets annoying and since it doesn't really change much then there it isn't a big deal to do so. Oh well.....
chum567 is offline
Old 10-04-2012, 09:18 AM   #74
slow3v
slow3v's Avatar
Fan#: 101709
What I Drive: 2012 Sterling Gray Focus SE MTX
FF Reputation: 1 slow3v Good Standing Member
technically the trans should be running very cool on long highway jaunts. No clutch slippage and no gear changes.
Sent from my SGH-I777 using FF Mobile
slow3v is offline
Old 10-04-2012, 09:54 AM   #75
gkirk
Fan#: 91903
What I Drive: 2012 C.Red Focus SE Sport Package
FF Reputation: 3 gkirk Good Standing Member
It might be a latency issue as well, which could explain why responses might be better with TCS turned off. Basically if the different computers need to talk to each other, there is a delay when signals and messages are sent back and forth, answers computed and sent back.
If you have say 3 computers doing this, it is easy for a small lag on two of them to cause a huge bottleneck for the whole system, as components hold up their computations waiting for answers from each other.
So what i wrote is pure speculation, but it would make sense that if one of the main components is just turned off, the remaining ones don't worry about it and do their own thing. Lag is gone.
Terms: Latency: this is the lag of a message going from one node to another. For example if a packet of information is sent from one component to another, it might take .1ms to get there. It doesn't matter what else is happening, this latency will always be there. If that packet is the computed on and sent back, another .1ms of latency is added to the total round trip, plus whatever the computation time took. Depending on how communication is set up between components, you might have many rounds of latency to take into account (which would appear as lag).
gk
Edit:
On my drive, the car seems smoother and slightly more responsive with TCS turned off. I need to test it more to be certain. Also, the car handles wet quite corners really well with TCS off :). I wasn't sure if it was using the stability control stuff on corners all the time or not.
If anyone wants an explanation of why 3 computing devices can slow down a lot under certain conditions that won't happen when there are just two, I can do that. lol. wikipedia does it better than I can. :)
http://en.wikipedia.org/wiki/Deadlock
gkirk is offline
Old 10-04-2012, 09:57 AM   #76
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
That is true for typical hydraulic automatics. Not so much for manual transaxles.
Hatch Nation #90
TboneZX3 is offline
Old 10-04-2012, 09:58 AM   #77
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
Points 4,343, Level 41
Points: 4,343, Level: 41 Points: 4,343, Level: 41 Points: 4,343, Level: 41
Level Up 97% Completed
I don't have a stutter issue, but what I noticed was that it seems to have less resistance to accelerate, and my mpg increased from 33.7 to 34.3 over 60 miles starting at 250 miles into the tank so it should have been stable by that point.
darkangelism is online now
Old 10-04-2012, 10:17 AM   #78
FordService
FordService's Avatar
Points 3,386, Level 36
Points: 3,386, Level: 36 Points: 3,386, Level: 36 Points: 3,386, Level: 36
Level Up 24% Completed
Forum Activity 24%
A big thank you to everyone who is posting their experiences with traction control!
If you're still having issues, please send me a PM so I can help out. All I need is your VIN, mileage, dealer, and daytime phone number; I'll get to work!
Thanks again,
Crystal
FordService is online now
Old 10-04-2012, 10:19 AM   #79
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Level Up 82% Completed
Forum Activity 12%
Originally Posted by smizak View Post
Tried it, still slips and marbles in a blender for me. Maybe I actually have a component problem.
Same here. I think I noticed less shudder off the line, but when I turned TC back on I couldn't get it to shudder again. So it's pretty much inconclusive for me. Clutch still sounds like marbles in a blender, though.
PratoN is online now
Old 10-04-2012, 10:21 AM   #80
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,268, Level 95
Points: 25,268, Level: 95 Points: 25,268, Level: 95 Points: 25,268, Level: 95
Level Up 92% Completed
Coming from an engineer, I love talking to customers and repair technicians on issues - and they love it too. But marketing says we "lack social skills" or something. Plus, we usually tell them too much. Then word gets out (for example) that "every clutch on every 2012 Focus is bad" and it ends up costing the company too much money. That's why they keep us locked in the basement.
Note: That was just an example - I don't work for Ford. I am, however an engineer stuck working in a basement with desks/cubicle walls from 1970 while the people upstairs are on like... their 4th remodel since 2000.
I hate to laugh, but I've dealt with numerous engineers and totally understand what you're talking about. Very unique people that many 'normies' probably can't handle
Originally Posted by F35-JSF View Post
I wondeur if the TCS needs to be reworked on all foci. I've stalled more than a few times thinking i didnt give it enough gas or that it didnt have enough torque.
Definitely not all Foci, because there are more people do not have the issue than there are those that do.
That being said, this is really interesting. I have no issues with my DCT, but I feel compelled to try driving with TCS off for a little bit to see if the car responds differently. And, if this is something that is helping some cars, it could be another tool that Ford could utilize in incorporating another possible fix avenue for those that do have the issue. While it won't solve everyone's issues, its beneficial even if it only helps a handful. But the connection would need to be made as to why this works and if no actual parts get replaced then there should be a programming change that keeps the end-user from having to go through such an elaborate process each and every time they drive their vehicle.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
