#31 | ||||
Pretty sure the lx didn't come with the bracket. If you have a zx3 you are good.
HN #171 |
#32 | ||||
Nope, Chuck Testa
Moved to "Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack"
#33 | ||||
Small update. I had noticed some slight play in the left front, like a bad ball joint or something. Upon some further inspection I found that either I or someone else had not fully tightened the strut to spindle bolt thus allowing movement of the spindle around the strut. After applying Chinese monkey death grip it is noe sufficiently tight and there is no free play at all. So lesson is...don't forget to tigten things. :)
Lucas 2011 Mustang GT 2013 Focus ST |
#34 | ||||
Those rear springs are SVT springs, for sure.
Don't know about the front springs. If one side (fender) is higher than the other, try disconnecting one end of one swaybar endlink and see if it settles out even. Reconnect it after the test. |
#35 | ||||
I could do that. But what will that tell me?
#36 | ||||
If the car isn't level, the reason can be a bent swaybar or mismatched end links forcing it to lean.
It just eliminates the whole swaybar setup from the possible causes list during troubleshooting. |
#37 | ||||
bushings
Does anyone know if this Energy Suspension 4-18119G kit is a direct fit for the svt's. I have a rear rattle and that rear bushing is worn out.
#38 | ||||
Hi 2 all from Moscow. Owning ST170 for 2 months, and have some questions about coilovers) now it has KYB UltraSR shocs + Eibah springs. I need to have some opportunity of adjusting height of a vehicle from stock (or Rus Spec FF1 = +1,5") to height of present Eibah spring height.
Does anybody know some coil kit for this terms? photo of present setup: ![]() Thx) |
