#61 | ||||
And definitely check out "The IT Crowd". One of the most funny shows on television (it's on Netflix). |
| Sponsored Links | |||
Advertisement | |||
#62 | ||||
I didn't notice any gigantic difference on my drive home with TCS off. That said, it did seem a tad better. I'll keep an eye on it...
(Note that I haven't had any major issues with my tranny to date) Quote:
That there is: Lawyers.
2012 Focus Ti Hatch | Ingot Silver | 401A, Nav, Winter Pkg, Moon Roof, Parking Tech. Pkg Build Date: 12/2/2011 | New APIM: 4/4/2012 MFT: Factory v2.11, 3/14/12 USB/Web > v3.0.2, 9/24/12 USB/Web > v3.2.2, 1/24/13 USB/Web > v3.5.1 |
#63 | ||||
Much better with TCS off
Here is what I noticed while specifically going through all situations I complained to dealer b4:
1. I can EASILY modulate engine response while in 6th gear when driving on the hilly highway. 2. Shifts are much quicker 1 to 4 when going from the dead stop 3. Downshifts ARE SO MUCH better from 6 to 5 4. I an easily modulate throttle for constant speed uphill with variable grade. In my case I think we've got a winner. No only if Ford will tell me wtf is wrong with TCS/AdvanceTrac. Thought it suppose to help you not handicap you? For everyone out there I would definitely suggest doing it then drive around some good hills |
#64 | ||||
TCS off greatly improved the shudder and clutch slipping when taking off from a stop for me. Since 12b37 this problem has been seriously annoying but havnt brought it in to service dept yet. Now with this TCS off the car is much better to drive. Before 12b37 the car was perfect shifting gears, almost seamless shifts and I never turned TCS off before either.
IMO its not the TCS that's flawed; its the software update 12b37 that caused it. A new update should fix it or if Ford would let us roll back to the previous DCT update that would work too. Hoping this find will help them to get us a fix soon! |
#65 | ||||
2012 Focus specs: http://media.ford.com/images/10031/2012_Focus_Specs.pdf 2013 Focus specs: http://media.ford.com/images/10031/2013_Focus_Specs.pdf 2013 Focus ST specs: http://media.ford.com/images/10031/2013_FocusST_Specs.pdf |
#66 | ||||
Hodor
#67 | ||||
Yes but is it actually the TCS itself or that the DCT clutches are misbehaving? Would slipping transmission clutches somehow play havoc with the TCS? I don't know the tie in between the two but I thought traction control generally worked related to the anti-lock brake system from wheel sensors sending wheel slippage info to a processor and braking info./force back to the slipping wheel(s). I can't see how turning the TCS off makes the trans work better but I don't doubt that it's occurring.
#68 | ||||
Hodor
I honestly have never turned the TCS off in my MT car. I'm going to try that and see if some of the hesitation I fell is reduced as well. There is a TSB out for the MT's as well, guys report that it wakes up the throttle response. I'm thinking it too backs off the torque management nanny. |
#69 | ||||
Tried it, still slips and marbles in a blender for me. Maybe I actually have a component problem.
#70 | ||||
Well, drove home with it off and drove back to work with it off today...not one instance of shuddering. There's a *tiny* bit of clutch slip on takeoff, but that I would expect (same as any manual car)...and it's *GREATLY* reduced from when I have the TCS enabled.
My theory is thus: one of the factors used in determining whether TCS should be engaged is the resistance on the drive shaft. When there's far less resistance than the computer thinks it should have, it engages the TCS to even it out. I'm using lighter wheels (21lbs as opposed to 32lbs stock wheels), so maybe I'm more at risk since there's already less resistance. Maybe I'm passed the tolerance of the computer and so the computer thinks the TCS should be engaged. This all makes sense since the shuddering *does* feel like it's being created artificially by the TCS. Also, the TCS doesn't just use the ABS to control tire movement. Traction Control can encompass more than just sitting on ice and revving the engine. It controls tire movement through the use of the braking, torque vectoring, fly-by-wire fuel management, and good old-fashioned clutch control. That means when it thinks the tire is slipping it might employ the brakes, it might put more torque on the opposing side, and/or it might cut the engine a bit and disengage the clutch to some degree. All of those factors together can easily account for shuddering. It's just amazing that not a single Ford engineer has figured this out before now. Good thing I have a phone call with a corporate engineer tomorrow :) Hope he know more about dry concentric dual-clutch transmissions than the last one. |
