Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013 Focus ST.
#1 | ||||
New ST3 Electric steering problems
After only 350 miles I'm finding it exhausting keeping it in a straight line on the motorway (freeway) over any distance.
The micro adjustments you would normally make to keep in your lane are impossible. At over 60 mph the electric power steering's 'pull drift compensation' is kicking in and stiffening the wheel making it difficult to move. Once it kicks in it is strong enough to hold the steering wheel off center with your hands off the wheel. Once you try and turn in the opposite direction there's sufficient resistance that once it does start to move it over compensates and you end up zigzagging in your lane. My car is only 3 weeks old :( |
| Sponsored Links | |||
Advertisement | |||
#2 | ||||
Mods: Drop in K&N filter, Steeda RSB, MS3 RMM, Remote start, Llumar tint, Ti engine cover, Husky floor mats, OEM splash guards |
#3 | ||||
#4 | ||||
welp...it sounds exactly like the symptoms I experienced with my defective steering rack.
Just because it doesn't fall into the dates of the TSB (which ford revised a few times) doesn't mean it isn't the problem.
#5 | ||||
#6 | ||||
Good luck OP, take it in to your dealership and reference that TSB, could very well be the case.
2012 SGM SEL Sedan 303a w/o Nav Job 1 built 6/2011 |
#7 | ||||
The TSB that's listed above may not be the particular fix for your car, but the symptoms you've described are exactly what I experienced. The fix was applied to my car and voila ... right as rain.
The issue for mine ended up being a steering rack that had been over torqued in the factory. Once the car was warmed up and at highway speeds, the "stiction" problem would rear its ugly head. At speed, the amount of electric assist drops off (as it should for better steering feel). It's when that assist drops off that there is not enough umph to overcome the slightly too tight situation in the rack. It may take Ford a little while to own up, but they will. Just be patient and take your new gem into the dealer. Here's another thread ... http://www.focusfanatics.com/forum/s...light=steering Oh, and ...
Gold Nugget: '12, Spec 400A, Winter Pckg, Yellow Blaze HB Mods: Llumar Tint:35 frnt, 20 rear; K&N drop-in; Splashguards Hatch Nation #174
#8 | ||||
#9 | ||||
Mine didn't, but I get where you're coming from. If that is the problem, it just might depend upon how minor the resistance is. Good luck!
#10 | ||||
It is the same problem as for the recall. overtightening bolta can reoccure anytime in production.
The op needs a new steering rack |
