New ST3 Electric steering problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 10-03-2012, 02:25 PM   #1
Shamone
Fan#: 104177
What I Drive: 2012 Blue ST3
Points 514, Level 10
Points: 514, Level: 10 Points: 514, Level: 10 Points: 514, Level: 10
Level Up 28% Completed
FF Reputation: 1 Shamone Good Standing Member
After only 350 miles I'm finding it exhausting keeping it in a straight line on the motorway (freeway) over any distance.
The micro adjustments you would normally make to keep in your lane are impossible. At over 60 mph the electric power steering's 'pull drift compensation' is kicking in and stiffening the wheel making it difficult to move. Once it kicks in it is strong enough to hold the steering wheel off center with your hands off the wheel. Once you try and turn in the opposite direction there's sufficient resistance that once it does start to move it over compensates and you end up zigzagging in your lane.
My car is only 3 weeks old :(
Shamone is offline
Old 10-03-2012, 02:51 PM   #2
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
http://www.focusfanatics.com/forum/showthread.php?t=282053
you need a new steering rack.
Some Guy From NY is offline
Old 10-03-2012, 02:53 PM   #3
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
Points 4,341, Level 41
Points: 4,341, Level: 41 Points: 4,341, Level: 41 Points: 4,341, Level: 41
Level Up 96% Completed
Forum Activity 6%
Originally Posted by Some Guy From NY View Post
This doesnt apply to him his car is newer than the steering rack issue.
darkangelism is offline
Old 10-03-2012, 02:57 PM   #4
Some Guy From NY
Fan#: 101517
welp...it sounds exactly like the symptoms I experienced with my defective steering rack.
Just because it doesn't fall into the dates of the TSB (which ford revised a few times) doesn't mean it isn't the problem.
Old 10-03-2012, 03:00 PM   #5
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 6%
That is true
Old 10-03-2012, 03:03 PM   #6
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
No doubt. Never know, they might have had back stock of the older racks when putting together the new car, and someone just didn't realize they were the older units that had the issues.
Good luck OP, take it in to your dealership and reference that TSB, could very well be the case.
Sonic Crew #28
feta_mgp is offline
Old 10-03-2012, 03:04 PM   #7
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
The TSB that's listed above may not be the particular fix for your car, but the symptoms you've described are exactly what I experienced. The fix was applied to my car and voila ... right as rain.
The issue for mine ended up being a steering rack that had been over torqued in the factory. Once the car was warmed up and at highway speeds, the "stiction" problem would rear its ugly head. At speed, the amount of electric assist drops off (as it should for better steering feel). It's when that assist drops off that there is not enough umph to overcome the slightly too tight situation in the rack.
It may take Ford a little while to own up, but they will. Just be patient and take your new gem into the dealer.
Here's another thread ... http://www.focusfanatics.com/forum/s...light=steering
Oh, and ...
Gold Nugget: '12, 400A, Wintr Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 / 20; K&N fltr + Snrkl Del.; Splashgrds; Grill Pinstripes
Hatch Nation #174
bsp_53 is offline
Old 10-03-2012, 03:13 PM   #8
Shamone
Fan#: 104177
Oh, and ...
Great description, and makes sense that the assistance drops off at speed, so if there is mechanical resistance you would notice it more. I wonder if this resistance will reduce once I get more miles on the clock?
Shamone is offline
Old 10-03-2012, 03:24 PM   #9
bsp_53
bsp_53's Avatar
Fan#: 87580
Mine didn't, but I get where you're coming from. If that is the problem, it just might depend upon how minor the resistance is. Good luck!
Hatch Nation #174
bsp_53 is offline
Old 10-03-2012, 04:36 PM   #10
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,253, Level 77
Points: 14,253, Level: 77 Points: 14,253, Level: 77 Points: 14,253, Level: 77
Level Up 51% Completed
Forum Activity 20%
It is the same problem as for the recall. overtightening bolta can reoccure anytime in production.
The op needs a new steering rack
Elizabeth is offline
