Titanium door handle locking - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2012, 04:59 PM   #1
rlift
rlift's Avatar
Fan#: 87930
What I Drive: 2012, White, Titanium
FF Reputation: 1 rlift Good Standing Member
The driverís door handle on my 2012 Titanium 4dr would not unlock/lock the door on days when temperature was above 70 or the door handle was in direct sunlight. The dealer could not find anything wrong with the handle, no error codes, contacted Ford and was informed that they need to apply a body control module update per a TSB.
Now I have this situation
Prior to update using the passenger door handle or a working drivers door handle
1. Place thumb over black square on door handle, first time the door locks, you can hear the click if no background noise and see the dashboard light if it is dark out
2. Press the square a second time, the horn honks signaling the alarm is active
This is the same as pressing the key fob lock button once, then the second time to hear the horn beep.
After the update, I can never get the horn honk signaling the alarm is active when using the door handle to lock the car.
I took my car back to the dealer and Ford is telling them that the horn should not beep when using the door handle to lock the car.
Does anyone else have a Titanium that the horn beeps when they lock the car using the door handle or was my car defective from the factory and now fixed? I liked hearing the horn beep so I knew my car was locked
rlift is offline
Old 10-02-2012, 05:09 PM   #2
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
Points 4,343, Level 41
Points: 4,343, Level: 41 Points: 4,343, Level: 41 Points: 4,343, Level: 41
Level Up 97% Completed
2nd press on black square honks for me, have scared myself washing the car.
darkangelism is online now
Old 10-02-2012, 05:17 PM   #3
Kabigon
Fan#: 88299
Points 4,391, Level 42
Points: 4,391, Level: 42 Points: 4,391, Level: 42 Points: 4,391, Level: 42
Level Up 21% Completed
Forum Activity 13%
An excellent question since I just updated the BCM a couple of days ago.
Before: Horn would beep if car was already locked. The problem was that there was no delay. In other words, if you locked the car (by touching the black square) and immediately (and often inadvertently) touched the black square again, the horn would beep.
Now: The horn does not sound and there is a delay (for confirmation) if the car is already locked.
For confirmation, I normally use the lamp on the mirror when locking the car.
I like the fact that the horn is no longer used. I don't like hearing or making unnecessary noise.
(why do I need to know that my neighbor just locked his car?)
Kabigon is online now
Old 10-02-2012, 07:26 PM   #4
noahsfocus
noahsfocus's Avatar
Fan#: 90974
Points 493, Level 9
Level Up 86% Completed
The horn honk on the second lock attempt is normal operation and I like the fact that the horn will honk twice if one of the doors is ajar when using the fob button. When touching the black square it won't lock or flash the lights when a door is ajar. Sounds like the BCM update has changed this feature ...I prefere it the way it is originally.
The horn honk feature is handy when using the FOB to find your car in a crowded parking lot or when it is out of the line of sight and you want confirmation it is locked. So does yours still honk when using the fob button? Or you just lost the honk when using the IA touch pad?
noahsfocus is offline
Old 10-02-2012, 10:00 PM   #5
rlift
rlift's Avatar
Fan#: 87930
Thanks everyone for their replies. It appears that anyone that had a BCM update lost the horn beep feature on the second press. Not sure why Ford changed the functionality or why the key fob works one way and the door handle is different.
rlift is offline
Old 10-03-2012, 12:27 AM   #6
jdetzel
Fan#: 102548
Points 173, Level 3
Level Up 46% Completed
Mine does not honk the horn with the door button. I can press it repeatedly and I hear the door lock cycle but no horn.
It will honk the horn if I press the remote a second time.
I also watch the mirror light, if there is a lot of noise I can not hear the lock.
jdetzel is offline
Old 10-03-2012, 11:12 AM   #7
DayGlow
Fan#: 102589
FF Reputation: 1 DayGlow Good Standing Member
Same for me
DayGlow is offline
Old 10-03-2012, 12:21 PM   #8
BlueIce
BlueIce's Avatar
Fan#: 93794
Points 1,732, Level 24
Points: 1,732, Level: 24 Points: 1,732, Level: 24 Points: 1,732, Level: 24
Level Up 32% Completed
FF Reputation: 2 BlueIce Good Standing Member
Mine honks every time, its so annoying. But it never used to do it, Im not sure what happened?
The story behind my avatar:
www.focusfanatics.com/forum/showthread.php?t=293992
BlueIce is offline
Old 10-03-2012, 12:53 PM   #9
Kabigon
Fan#: 88299
Forum Activity 13%
The fob works as always (the horn sounds if doors are already locked).
Only the operation of the door handle pad was changed.
Old 10-03-2012, 12:53 PM   #10
xpartmgr
xpartmgr's Avatar
Fan#: 96709
What I Drive: 2012 White Ford Focus Titanium
FF Reputation: 2 xpartmgr Good Standing Member
I am not sure what you mean by this? Perhaps a different way to lock the car????
I always use the handle and mine will honk if touched twice.
Build date 8/11/2011 - MFT no Nav V 3.2.2- new SJB (Smart Junction Box) installed on 6/23/2012 with reprogramming of BCM
xpartmgr is offline
