#1 | ||||
Source needed for 2.3 Oil Pan Gasket
Hey,I am looking to do the ST 2.3 balance shaft delete (Cosworth) and need to know where to get a new oil pan gasket?
Help appreciated.
I used to be DueceCoupe,but now I gots a 4 door! ST Crew Member # 666 |
| Sponsored Links | |||
Advertisement | |||
#3 | ||||
Is that our only option?
Dealer parts are pretty pricey....hoping there was an aftermarket available....
#5 | ||||
Yep, no gasket...see above ^^^
Autolite 103's, Cosworth CAI, FRPP Suspension, Strut Bars, DIY Short Shifter, SVT Air Dam, BSD, Poly Trans Mount... Duratec Crew #55 Hatch Nation #55 |
#6 | ||||
RTV & use a plastic blade on the block & pan= you don't want to nick the surface. Take your time= don't hustle it. Also be prepared for the balance shaft's weight, it was heavier then I thought. It's well worth it. Enjoy the freer revving motor.
#7 | ||||
Did You notice a lot more vibration with the BSD? Is anyone running the BSD with aftermarket mounts or cams? Rep added for all who helped.
#8 | ||||
yes there is some vibes at idle only= but its well worth it.
#9 | ||||
I have less vibration with the BSD and Dogbone mount now. The reason is my upper motor mounts were shot and I didn't know it until I did the BSD and Dogbone...the car shook like hell!! So I changed the upper mounts the next day and the car was quieter and smoother than before.
All good mods though. Enjoy it!
#10 | ||||
My motor mounts should all be fine,the Car only has 9000 miles on it. Just worried with the 3/4 Crower cams,BSD and the dog bone mount,its going to vibrate like crazy. But as much as I drive the Car,it shouldn't be a problem. The BSD gave noticable gains? I have read up to 5 HP gains were proven....can this be right?
