2002 SE Strut replacement Q's - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2012, 06:52 PM   #1
BestMistake
Fan#: 104458
What I Drive: Black 2002 Ford Focus SE
FF Reputation: 1 BestMistake Good Standing Member
Hey guys I am replacing my 2 front struts and have run into some problems. I have everything detatched, tie-rod, brakes, wheel speed sensor and sway bar link. I brought up the tab on the back of the strut and it will not move up and down, only side to side. Do I need to remove the ball joint? Or is there another way to get it out of there? There seems to be a tab on top of the ball joint inbetween it and the knuckle will that prevent it from coming out? Thanks for the help.
BestMistake is offline
Old 10-02-2012, 07:02 PM   #2
Elder
Points 12,807, Level 73
Points: 12,807, Level: 73 Points: 12,807, Level: 73 Points: 12,807, Level: 73
Level Up 90% Completed
Um...
I may be missing something here, but it seems you did a LOT of extra work without hitting the key area, the bolt that holds the strut in the knuckle.
The bolt passes through a notch in the tab, so it has to be removed completely.
That and the sway bar link is all that attaches to the strut at the bottom....
luck!
sailor is offline
Old 10-02-2012, 07:05 PM   #3
BestMistake
Fan#: 104458
Lol yeah I got that out! That's why it doesn't make much sense that it's not coming out. Is it just frozen there?
Old 10-02-2012, 07:18 PM   #4
Elder
Oh yeah, it is for sure!
A LOT of penetrant, around the top & in that slot by the tab, wiggle & jiggle....
bash the knuckle downwards....
drive a screwdriver or similar wedge into the slot below the tab if you can to spread it a little...
If it's a REAL PITA, just put it back together & wait a week for the penetrant to help, squirting more on as possible....
sailor is offline
Old 10-02-2012, 07:21 PM   #5
Elder
A pry bar of some sort to tension the suspension downwards helps, since the bushings try to keep the arm up when it's at full extension downwards.
That kinda negates the bashing you're doing on the knuckle to move it downwards.
I got it done doing both at once when I pulled the old ones to install my SVT suspension....
Luck!
sailor is offline
Old 10-02-2012, 07:23 PM   #6
Elder
Those pinch bolts were a bit frozen as well on mine, even though there wasn't much rust evident on the outside salt water must collect nicely in that strut socket of the knuckle....
sailor is offline
Old 10-02-2012, 07:52 PM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,678, Level 86
Points: 18,678, Level: 86 Points: 18,678, Level: 86 Points: 18,678, Level: 86
Level Up 66% Completed
Forum Activity 18%
Originally Posted by sailor View Post
Drive a screwdriver or similar wedge into the slot below the tab if you can to spread it a little...
Best way IMO.
It's always worked for me.
iminhell is offline
Old 10-02-2012, 11:58 PM   #8
my_beautious_ZX3
Fan#: 32386
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
that would probably just snap the tip off of the screwdriver.
When my strut was seized in the knuckle, this was the only trick that worked:
http://www.focusfanatics.com/forum/s...=118282&page=2
my_beautious_ZX3 is offline
Old 10-03-2012, 02:44 AM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 18%
^ though a novel approach, that method can damage the treads of the bolt by mushrooming the tip. Then you have to buy a new bolt.
A wedge type tool is the best option.
iminhell is offline
Old 10-04-2012, 12:18 AM   #10
my_beautious_ZX3
Fan#: 32386
^nah, it's a grade 8 bolt. If that's all it took to mushroom a suspension bolt, then we're all in trouble.
