Select Shift "Sport Start" - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2012, 10:46 AM   #11
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
Originally Posted by darkangelism View Post
Yes and it works like one too, but there is no ford document that I have found that calls it this or says it has this feature.
Perhaps for liability purposes.
BetaDnB is offline
Old 10-02-2012, 11:35 AM   #12
raptor1956
Fan#: 97725
Points 4,363, Level 42
Points: 4,363, Level: 42 Points: 4,363, Level: 42 Points: 4,363, Level: 42
Level Up 7% Completed
I've never tried the launch mode and doubt I ever will.
I do use "S" mode manual all the time, however, as it's a good way to limit unnecessary gear changes when cruising on rolling roads. For example, if I'm cruising at 60mph on gentling rolling roads in "D" mode the car will tend to downshift when climbing even a slight grade but if I have it in "S" mode manual and put it in 6th (manual) the car will not downshift unless the speed drops too much. I'll leave it in 6th unless it drops a few mph then thumb-shift down as needed.
Additionally, in "D" mode it will downshift going down a hill if the speed increases even a little above cruise setpoint, but in "S" mode manual it will not down shift unless you do it.
Brian
raptor1956 is online now
Old 10-02-2012, 12:27 PM   #13
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
It probably is a launch control. Why not program that into a DCT? It probably isn't mentioned because Ford doesn't want to replace a lot of clutch packs under warranty. They can still claim misuse or abuse since they did not state it as a feature of the car, same as if you did the same frequently with a manual shift Focus. The rpm's do seem right for a good, not too aggressive launch, about the same as you would do with a manual.
AZfocus2012 is offline
Old 10-02-2012, 01:32 PM   #14
cjanderson629
cjanderson629's Avatar
Fan#: 91376
What I Drive: 2012 Sterling Grey Focus Ti
FF Reputation: 1 cjanderson629 Good Standing Member
Just messed around with it in D, the further you hold in the brake, the higher the RPMs will go.
cjanderson629 is offline
Old 10-02-2012, 01:38 PM   #15
AZfocus2012
Fan#: 92484
Sounds even more like a launch control, letting the driver choose the desired RPM range prior to launch.
Old 10-02-2012, 04:24 PM   #16
MyThIc3LiTe
MyThIc3LiTe's Avatar
Fan#: 95163
This is for all intents and purposes launch control without having a button for it, I believe 2011 Audi S4s also do just this. No button, you just press the brake in any mode and press the gas.
If you were just pressing brake and gas as you do at a stop, it won't go above 1k. This is the safety cutoff and eventually you'll get brake override.
But if you bury the brake the RPMs will shoot right up and settle, just in the perfect spot for a nice launch.
It certainly pulls better off a start when you do it.
MyThIc3LiTe is offline
Old 10-02-2012, 07:37 PM   #17
Albarry
Sonic Crew #016
Albarry's Avatar
Fan#: 87877
What I Drive: 2012 Sport completely stock, DCT
Points 3,558, Level 37
Points: 3,558, Level: 37 Points: 3,558, Level: 37 Points: 3,558, Level: 37
Level Up 39% Completed
FF Reputation: 8 Albarry Good Standing Member
I tried it today, launched at 2500 rpm.
(STORM THE ALBATROSS) SC016 RR054 SR251 [HOONIGAN]
Albarry is offline
Old 10-02-2012, 10:49 PM   #18
st falcon
st falcon's Avatar
Fan#: 92343
What I Drive: 2012 Blue Candy HATCH SEL
FF Reputation: 3 st falcon Good Standing Member
launch mode in a non-ST/RS focus huh? unlikely.
2012 Focus SEL Blue Candy Metallic
1996 Bronco XLT 351W
Cant wait for Summer when I pop the top!!
st falcon is offline
Old 10-02-2012, 11:01 PM   #19
Points 10,243, Level 67
Points: 10,243, Level: 67 Points: 10,243, Level: 67 Points: 10,243, Level: 67
Level Up 49% Completed
Forum Activity 33%
A secret hand shake and a bit of fun for the engineers to sneak that past the bean counters to take advantage of the dual clutch transmission is unlikely? Considering it seems to set the car up for a quicker launch than just matting the accelerator pedal it seems more likely that it is a form of launch control rather than just a self preservation mechanism. After all if you matted both the gas and the brake while driving its supposed to cut off the throttle via brake override.
suss6052 is offline
Old 10-02-2012, 11:14 PM   #20
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,914, Level 76
Points: 13,914, Level: 76 Points: 13,914, Level: 76 Points: 13,914, Level: 76
Level Up 66% Completed
FF Reputation: 12 NickCornell Great Standing Member
Go ahead and try it
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
