#1 | ||||
Will these rims fit my focus?
http://london.kijiji.ca/c-cars-vehic...AdIdZ418870971
5x108 bolt pattern, i wanna pick them up to throw some winter tires on! |
Remove Advertisements |
#2 | ||||
Sonic Crew #09
Looks like they will. Just make sure the hub size on them is the same as the focus or bigger.
Coils, Skid plate, Billet grille, Steeda CAI and STS, FSwerks Stealth Exhaust, ST spoiler, Zetec S body kit, Mid Wing, Bojix Lip, Steeda prototype engine cover Sonic's MK3 Crew #9 Chaos! |
#3 | ||||
Sonic Crew #09
The hub size on the focus is 63.4. If these rims have a bigger hub size then you need to get hub centric rings. Hope that helps.
#5 | ||||
Plus "offset", which is the the distance between the center point of the rim and the surface where the wheel meets the hub on the car. The Focus' offset is +50mm, I think. I wouldn't want to vary from that by more than 5 or 10mm. Odd handling, poor straight-line stability, even accelerated bearing wear can occur.
You can find a better explanation of all this at Tirerack.com. |
#6 | ||||
i think you could do better with rims than those. but its your personal style
Most Excellence! #586 of #4788 |
