RPM at idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2012, 07:53 AM   #1
solarboy
Fan#: 104327
What I Drive: 2004 Focus SE - Wagon with SPI
FF Reputation: 1 solarboy Good Standing Member
RPM at idle
Hello Foci Fanatics
What is the ideal RPM at idle once engine is warm?
How do you adjust RPM? Is there an adjustment screw on throttle?
Cheers
Eric
solarboy is offline
Old 10-21-2012, 11:22 PM   #2
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Cannot adjust, electronically controlled by PCM.
amc49 is offline
Old 10-22-2012, 09:26 AM   #3
Focusblackzx5
Focusblackzx5's Avatar
Fan#: 95212
What I Drive: 2012 Mitsubishi Lancer
Points 1,323, Level 20
Points: 1,323, Level: 20 Points: 1,323, Level: 20 Points: 1,323, Level: 20
Level Up 23% Completed
FF Reputation: 1 Focusblackzx5 Good Standing Member
Originally Posted by solarboy View Post
Hello Foci Fanatics
Cheers
Eric
the ideal rpm at iddle is around 850
2012 White Mitsubishi Lancer 2.0L : New car
2005 Black Ford Focus zx5 SES : Trade In
2003 Arizonna beige Ford Focus SE : Sold
Focusblackzx5 is offline
Old 10-22-2012, 02:39 PM   #4
Svizzara
Svizzara's Avatar
Fan#: 98554
What I Drive: '01 SPI Sedan
Points 408, Level 8
Points: 408, Level: 8 Points: 408, Level: 8 Points: 408, Level: 8
Level Up 16% Completed
FF Reputation: 1 Svizzara Good Standing Member
Mine's usually in the mid 800s. I'd imagine you'd have to tinker with the ECU to adjust it... but I can't think of a reason why you'd want to!
Svizzara is online now
Old 10-22-2012, 08:41 PM   #5
Focusblackzx5
Fan#: 95212
if it's 800-850 should be alright :P no need to adjust that ;)
Old 10-28-2012, 08:39 PM   #6
Tymes
Fan#: 94124
What I Drive: 02 SE SOHC SPI
FF Reputation: 8 Tymes Good Standing Member
850? Really? Once mine is at full temp she idles around 680 to 710. I thought that was normal cause I owned a few VWs and they usually idled at 700.
Somewhere there's a DC10 struggling to get off the ground. I'm not a fan of wings on street cars, I like low key spoilers, but not something that you have to custom order from Boeing.
Tymes is offline
Old 10-28-2012, 10:15 PM   #7
Focusblackzx5
Fan#: 95212
Yeah, between 750 and 800..here's mine..it,s a bit high because it was just after the second start up from the gas station...but yeah between 750 and 800.
I have the Duratec. Maybe it revs a bit higher
Old 10-30-2012, 06:41 PM   #8
Tymes
Fan#: 94124
Mine is on my Garmin which connects to the ECU. It was actually idling even lower then I stated.
Tymes is offline
Old 11-01-2012, 01:13 AM   #9
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Points 4,699, Level 43
Level Up 75% Completed
The idle value will be different in gear vs. out of gear and ATX vs. MTX.
At fully warmed up and heat soaked our SPI ATX:
- in gear averages 650 rpm
- out of gear averages 700 rmp
60k+ miles.
a_2000_se is offline
