TSB 12B37 - New? - Page 57 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-17-2012, 04:56 PM   #561
Points 10,052, Level 67
Points: 10,052, Level: 67 Points: 10,052, Level: 67 Points: 10,052, Level: 67
Level Up 1% Completed
Forum Activity 23%
I get your point, but what % of owners have to "get a bad one" before we conclude its a "bad transmission"? I find it hard to believe any transmission on any modern car has been this troublesome to its owners this early in its life.
It doesn't seem to matter whether the issue is design or quality control: both can create problems, both can be fixed; the owner is in the same position either way.
6F35 (the light duty torque converter based planetary transmission) from the Fusion/ Escape/ et al a few years back was having all sorts of shift flare issues and generally falling apart very early, and that's a very firmly established technology by now. But Ford always had trouble with the FWD torque converter automatics all the way back through the 4F50N, AX4N, AX4S, AXOD-E, AXOD, etc...
suss6052 is offline
Old 09-30-2012, 02:03 AM   #562
sam.noside
sam.noside's Avatar
Fan#: 104368
What I Drive: 2012 Candy Red 5dr HB SEL
FF Reputation: 1 sam.noside Good Standing Member
Newbie: How do I know if I've got this?
We are looking at buying a 2012 Candy Red 5dr Hatchback SEL, which we fell in love with. Its a 2012 with 6 Speed AT. 36,000 miles. It drove fine. Are we past the "trouble point"? Is this a "good transmission"? Or are all 2012's doomed to trouble...
sam.noside is offline
Old 09-30-2012, 07:19 AM   #563
Timthom62
Timthom62's Avatar
Fan#: 97579
Points 2,703, Level 31
Points: 2,703, Level: 31 Points: 2,703, Level: 31 Points: 2,703, Level: 31
Level Up 69% Completed
To see if any Field Service Actions, such as 12B37, are open against the vehicle, go to the Ford ETIS site and enter the VIN of the vehicle. LINK
This is the Ford Europe site, so the vehicle build date will be in European format (i.e. 30.09.2012 for September 30, 2012) and also shows the vehicle configuration and options.
As for the other question, it's hard to say if the car you're looking at has a transmission that will be trouble free or not. We have three 2012 Foci in our family, all with the DCT and no issues so far with any of them. However, being a mechanical thing, and one whose design might have benefited from a bit more refinement prior to its initial release, it's hard to say that past performance is a reliable guide for future performance.
If you like the SEL you're looking at, that's a call you'll have to make for yourself. We can all give opinions, but nobody can give you a guarantee. All I can really say is that I really like my SEL and would make that purchase decision again without hesitation.
2012 Red Candy 5-Door SEL 303A (built 2/27/12)
2012 Sonic Blue 5-Door SE Sport 203A (built 9/13/11)
Timthom62 is offline
Old 09-30-2012, 08:26 AM   #564
sam.noside
sam.noside's Avatar
Fan#: 104368
Tim,
Thanks for the answer and the link. This is what I'm shown:
Focus (C346N), 2.0L Duratec DI TIVCT (160PS), Race Red
Outstanding Field Service Actions
12B37 - , AND THE ANTI-LOCK BRAKE SYSTEM (ABS) MODULE
Primary Features
Build Date: 22.06.2011
Vehicle Line: Focus (C346N)
Body Style: 5 Door Saloon
Series: Sel Version
Engine: 2.0L Duratec DI TIVCT (160PS)
Transmission: 6 Speed Auto Transmission DCPS
Drive: LHD FWD
Emission: 50 State Emission Requirements
Air Conditioning: Dual Zone Auto Temp Control A/C
(Plus a long list of other options I could append, but will point out these:)
Michigan Plant Built
Fleet
Because it says Outstanding 12B37, I assume the transmission problem a) was not applied at the factory, and b) has not been applied to this vehicle. Right?
Is there any correlation of the December build to this or any other problem? Put differently, is there anything that a December build in Michigan tells me?
Is there anything else that pops out that I should "pay attention to" in terms of things that others have had troubles with?
- Sam
Old 09-30-2012, 08:51 AM   #565
Timthom62
Timthom62's Avatar
Fan#: 97579
True, if it shows 12B37 as outstanding, then the 12B37 software update for the PCM/TCM/ABS has not been applied.
I'm not sure what you mean by "December build". Looking at the ETIS info there, it appears that the car was built on June 22, 2011. As FSA 12B37 only started at the beginning of May 2012, there's no way the update would have been done on the production line and it appears that the previous owner did not have this accomplished.
You'll find plenty of other threads about issues others have found, but two of the big ones have been issues with the MyFordTouch (MFT) system and problems with clunking and rattling noises from the front suspension.
I'm not sure if the car you're looking at has MFT or not, but many folks have experienced quite a few different glitches with this. I have it on my car and have not experienced anything at all like that, but others have.
The clunk/rattle seems to come from the upper attach points of the left and right front suspension and seems to happen more at low speeds. The best way to check for this is to drive slowly over some speed bumps and listen for the clunk/rattle. Our SE Sport has this and, while annoying, it doesn't appear to be a safety issue.
Ford is still working on both of these issues, and the transmission ones as well. While a lot of us would be happier is they'd maybe resolve them a bit quicker, at least they are still trying.
Old 09-30-2012, 09:24 AM   #566
sam.noside
sam.noside's Avatar
Fan#: 104368
Tim,
Doh! Even after your explanation I read Build Date: 22.06.2011 as December, not June. You're right.
I don't have My Ford Touch. At least I pretty sure. There is a little screen in the cockpit, but not big enough for MFT, and I don't see MFT on the extended list of features. It does however have the Microsoft Sync.
(I'd attach an image, but I can't figure out the image upload, even with 30 years experience with computers... )
Thanks again.
Old 09-30-2012, 11:24 AM   #567
Timthom62
Timthom62's Avatar
Fan#: 97579
Tim,
Thanks again.
Sounds like 'SYNC with MyFordTech', which is different from MFT. We have that on our SE and are very happy with it.
Glad I was able to provide some assistance. Best of luck with your new Focus!
