Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus > MK3 Interior Mods & Upgrades
Old 09-08-2012, 08:46 AM   #1
Chickenmuffn
Fan#: 103458
What I Drive: 2011 Focus Zetec 1.6
FF Reputation: 8 Chickenmuffn Good Standing Member
How to: Aftermarket footwell lighting
NOTE: This was done on a Euro 2011 Ford Focus MK3
My Focus didn't come with footwells so I decided to install them today. Took me about 2 hours.
First I located the fuse box which, for my car, was in the left footwell. To access the fuse box there are 2 plastic bolts that hold up a stiff piece of cloth that covers the fuse box. Squeeze and twist them off.
The indicated fuse is a fuse that is activated when the key is in the "ON" position. There should be a 10amp fuse is there, I forgot to put it back in for the picture. I'm using a add-a-circuit fuse tap so that the footwells turn on only when the key is in the ON position
I then threaded some wires behind the center console. I zip tied a twig to the wire and threaded it though the back.
By chickenmuffn at 2012-09-08
Here is the left side LED strip, I soldered the add a fuse to the positive of the LED and soldered some black wire to the GND just to extend it
This is the right side LED strip soldered to the wires I threaded eariler
Mounted the LED's using double sided tape to underneath the dash, making sure the glove box would clear the strips.
Connected the left and right GND wires using a ring connector, and bolted that connector to a metal screw I found underneath the glove box.
By chickenmuffn
The positive wires were solder together and then connect to the add-a-circuit which was theninserted into the above indicated fuse slot.
Cleaned up the wires, reattached the stiff cloth piece and turned the key to the ON position. This was taken in broad daylight. Will take another one tonight.
Chickenmuffn is offline
Old 09-08-2012, 09:30 AM   #2
MotorcityJAX
Sonic's MK3 Crew #14
MotorcityJAX's Avatar
Fan#: 90253
What I Drive: 2012, White Platinum, 5 Door SEL
FF Reputation: 6 MotorcityJAX Good Standing Member
Nice write, great job
2012 SEL 5 door, "Project Stormtrooper"
Hatch Nation #169
Sonic Crew #14 Metal Tails
Rally Rev #16
MotorcityJAX is offline
Old 09-14-2012, 07:06 AM   #3
BLarson
BLarson's Avatar
Fan#: 58905
What I Drive: 2012 Ox White SE Sports Pack Hatch
FF Reputation: 6 BLarson Good Standing Member
Looks rad. Great write up.
BLarson is offline
Old 09-29-2012, 02:01 AM   #4
dpando1
Fan#: 92144
What I Drive: 2012, Grey, Focus SE Sport Package
FF Reputation: 2 dpando1 Good Standing Member
right on!
dpando1 is offline
Old 10-05-2012, 09:32 AM   #5
Rownan
Rownan's Avatar
Fan#: 103249
What I Drive: 2013 Ford Focus ST
FF Reputation: 1 Rownan Good Standing Member
Great write up, and nice Onitukas!
I'm planning something similar, already got my LEDs from onzium. But I also want them to come on with the fob, door unlock etc.. I'm hoping to piggyback on the interior dome circuit for that, using diodes so I don't bridge circuits. This of course requires the dome circuit to be positively switched. I HOPE HOPE HOPE it's not negatively switched. But I'm not sure, since I haven't put a multimeter on it yet.
Any clue if our dome is negatively switched?
Rownan is offline
Old 10-05-2012, 10:06 AM   #6
Chickenmuffn
Fan#: 103458
Have you thought about wiring them directly to the sidelights/sidemarkers?
Old 10-05-2012, 10:34 AM   #7
Rownan
Rownan's Avatar
Fan#: 103249
interesting thought. Are those controlled by a light sensor or are they always on when the car is on?
I was hoping to tap into something in the interior fuse panel like you did, using an add-a-circuit. I'm guessing sidemarkers are powered from the under hood panel. Hoping to avoid running wire through the firewall.
Rownan is offline
Old 10-05-2012, 10:45 AM   #8
Chickenmuffn
Fan#: 103458
At least for my Euro focus, my sidelights turn on when I unlock my car and stay on until I open and close my door. Then of course I can control them when I'm driving.
I don't think its possible to fuse tap the sidelights because they are controlled by a computer... You would have to directly tap the wire near the headlights :/
Or you can pull down the dome lights whip out the multimeter.
Old 10-05-2012, 11:11 AM   #9
Rownan
Rownan's Avatar
Fan#: 103249
Yeah I'll be putting a multimeter on it this this weekend. I'll probably check the OEM footwell lighting, as it seems to be running on the same circuit as the dome.
Rownan is offline
