Sponsored by Tire Rack
Sponsored By:
Tire Rack
Old 06-18-2012, 05:25 PM   #81
Sniperx
Sniperx's Avatar
Fan#: 99628
What I Drive: 2004 White ZX3, 1985 BMW M535 Dinan
FF Reputation: 2 Sniperx Good Standing Member
OK OK OK! I am all confused now man! I have a 2004 ZX3 hatch zetec and want to do a full SVT front and REAR brake set up on it. Will it ALL bolt right up including the suspension?
Sniperx is offline
Old 06-18-2012, 08:49 PM   #82
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
Brake upgrades
Originally Posted by Stui420 View Post
I have an 01 ZX3 stock brake setup. i am wanting to go to the larger 278mm setup on the front.
i dont know what its called but i also need to know if i need to use a different part with this new setup or if the old one is the same heres the pic of it..
EXAMPLE---CALIPERS/05
Calipers/?= use svt= the piston diameter is bigger
Rotors/?= use the 300mm svt
Ball Joints/?=the '05+ use the bigger taper ones
Spindels/?= use the '05 ones, the '06+ use a bigger diameter strut
Brake Lines/?
= stock will work, Stainless steel is best
The '05 spindle uses the earlier strut & uses a bigger tapered ball joint stud, so you'll have to change your LCA's for '05+ arms.
felixthecat is offline
Old 06-18-2012, 08:53 PM   #83
felixthecat
Fan#: 80663
Yes it'll all bolt on.
Yes it'll all bolt on.^^^^ Now the bad news= the rear kit has been discountined. So you'll have to look at used parts. svt=11'' rotors/ st=10'' rotors.
Old 06-18-2012, 09:58 PM   #84
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
FF Reputation: 7 Blue5ive Good Standing Member
Buy-Sell-Trade Rating: (8)
More bad news. Ford has also discontinued the front knuckles so you cannot piece together a new kit. Options are: you can buy a new complete svt front brake kit that bolts up to any 00-04 model from Tousley Ford for about $485+ shipping. Only 8-10 left and Ford does not make them anymore. Or you can buy a used front kit. For the rear you can use any rear disc brake setup from any 00-07 focus but you need the complete rear kit most critical being the caliper mounting brackets. There is also a Baer rear kit for $600+ that uses 12" rotors but uses '98 chevy calipers on a custom bracket.
Team Focalize
Hatch Nation #9
"Some people feel the rain, others just get wet"
Blue5ive is offline
Old 09-28-2012, 05:45 PM   #85
Rob axel
Fan#: 90670
What I Drive: 08 f-250 van
FF Reputation: 1 Rob axel Good Standing Member
I have a 03 SE non-ABS no traction control Zetec I am looking at upgrading the front brakes....After reading this thread I found this...
http://www.summitracing.com/parts/FMS-M-2300-SVTF4/All/
$600... and from what I can see, direct bolt on...no mods...
I was looking at salvage yards...trying to obtain BETTER performing brakes than what I have...I am not into high performance....I just want the car to stop when you apply pressure to the pedal...
It says "use with rear disc brakes set up"....dont see any reason why you cant install on w/ rear drums?
Rob axel is offline
Old 09-28-2012, 05:56 PM   #86
Sniperx
Sniperx's Avatar
Fan#: 99628
That looks like a kit to upgrade stock NON SVT brakes to SVT brakes. I want to do that to mine. I also want to do the rear discs for mine too.
Hatch Nation Member #165
Resistance is not Futile, it is voltage divided by current.
Sniperx is offline
Old 09-28-2012, 08:31 PM   #87
_ANTI
_ANTI's Avatar
Fan#: 92550
What I Drive: 2003 infrared SVT
FF Reputation: 1 _ANTI Good Standing Member
I'm not sure why it says that the "must be used with rear disks". I have defiantly done sketchier things to my cars... But 600 is a bunch of cash to throw at brakes.
Bone Stock Infra-Red 2003 SVT #2762 of 3985
_ANTI is offline
Old 09-28-2012, 09:38 PM   #88
felixthecat
Fan#: 80663
My foot is playing w/ pressure & not distance
Thats cheap if it keeps you out of an acciendent & all the hassells & issues that go w/ it. From 10'' to 11.8'' & bigger calipers is great & thats with new Ford parts. I'd add a set of stainless steel lines to that. I have 13'' & 11.75'' brakes just to say. My foot is playing w/ pressure & not distance.
Old 09-28-2012, 10:16 PM   #89
Geezer
Fan#: 1427
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
It's for brake bias reasons. Brake bias is generally based on a number of variables including net weight, weight distribution, gross weight, speed, etc.
Geezer is offline
Old 09-28-2012, 10:24 PM   #90
Geezer
Fan#: 1427
Good braking is obtainable from the stock setup. There are components that can make it work better such as street performance pads and/or shoes plus fresh brake fluid (importance is often overlooked) and possibly an upgrade to braided brake lines (improves pedal feel). If rotors or drums are worn they should be replaced with good quality OE parts. There's no need for drilled, slotted or for that matter, oversized rotors.
Geezer is offline
