Disconnected transmission tube, problem? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-26-2012, 04:58 PM   #1
xwhit3devilx
xwhit3devilx's Avatar
Fan#: 86578
What I Drive: 2014 Hyundai Veloster Turbo
Points 5,510, Level 47
Points: 5,510, Level: 47 Points: 5,510, Level: 47 Points: 5,510, Level: 47
Level Up 80% Completed
FF Reputation: 2 xwhit3devilx Good Standing Member
Question Disconnected transmission tube, problem?
So today when I went to check my oil and other fluids I noticed something bizarre. Down behind the air box there was a plastic tube connected to a vacuum line type hose that was just sitting around out of place. After looking around I found a hole on top of the DCT where the tube would appear to fit. I noticed a bit of oil (tranny fluid?) was caked around where the hole is and there was still some oil fresh inside it.
Here's a picture of the tube (I pulled it up a bit to take the picture, it was down behind the air box when I found it)
And here's a picture of the hole
First of all; what the heck is this thing? Why would it have come out? And is it a problem that it was disconnected? Could I have lost fluids that will need to be replaced?
Just a note, I check my cars fluids weekly and this was NOT detached last week. (I haven't touched the car since then so I'm fairly certain I didn't accidentally knock it out of place) And yes, I did put the tube back where it belongs after I finished taking the pictures.
xwhit3devilx is offline
Old 09-26-2012, 05:25 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Looks like a vent tube
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 09-26-2012, 05:39 PM   #3
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
+1. Trace down the other end of that tube and see where it leads. I wouldn't be surprised if it is vented to atmosphere.
If you'd lost any gear oil, you would see remnants of it around the hole. It looks pretty clean to me. I would put the vent tube back in the hole, check the fluid level at the fill plug, and mention it to the dealer's service dept next time I'm in.
Hatch Nation #90
TboneZX3 is offline
Old 09-26-2012, 11:28 PM   #4
dan50
Fan#: 91789
Points 3,026, Level 33
Points: 3,026, Level: 33 Points: 3,026, Level: 33 Points: 3,026, Level: 33
Level Up 84% Completed
Forum Activity 6%
Can't imagine how that was able to become disconnected. It does look like a fair amount of grit worked its way around the opening and some probably got into the opening itself. Assuming this is a vent tube, the grit could have worked itself into the transmission itself, which is not a good thing. Guess I would discuss with the dealer and try to get the fluid changed soon.
dan50 is offline
Old 09-26-2012, 11:32 PM   #5
frinesi2
frinesi2's Avatar
Fan#: 95914
Points 122, Level 2
Points: 122, Level: 2 Points: 122, Level: 2 Points: 122, Level: 2
Level Up 44% Completed
FF Reputation: 1 frinesi2 Good Standing Member
+1 on the vent tube. I can't confirm 100% of course, but on many a forum I have seen threads like this.
2012 Focus SE Hatch 5spd sport package, Tuxedo Black Metallic
Road Magnet springs and fuzzy dice on the mirror
frinesi2 is offline
Old 09-27-2012, 03:05 PM   #6
FordService
FordService's Avatar
Points 3,364, Level 36
Points: 3,364, Level: 36 Points: 3,364, Level: 36 Points: 3,364, Level: 36
Level Up 10% Completed
Forum Activity 20%
Originally Posted by xwhit3devilx View Post
So today when I went to check my oil and other fluids I noticed something bizarre. Down behind the air box there was a plastic tube connected to a vacuum line type hose that was just sitting around out of place. After looking around I found a hole on top of the DCT where the tube would appear to fit. I noticed a bit of oil (tranny fluid?) was caked around where the hole is and there was still some oil fresh inside it...
First of all; what the heck is this thing? Why would it have come out? And is it a problem that it was disconnected? Could I have lost fluids that will need to be replaced?...
... Guess I would discuss with the dealer and try to get the fluid changed soon...
Hi xwhit3devilx,
As dan50 has suggested, I would recommend that you swing by your dealership so they can inspect. They'll be able to tell you what the tube is and replace any lost fluids, if necessary.
Feel free to reach out to me via PM if you need additional assistance.
Thanks!
-Crystal
FordService is offline
Old 09-27-2012, 11:07 PM   #7
xwhit3devilx
Fan#: 86578
Thanks everyone. The car seems to be driving (and shifting) fine for now, so I'll just mention it next time I get my oil changed as suggested. I probably overreacted, but given the number of issues people have had with the DCT I figured I'd ask around here to be sure.
Old 09-28-2012, 08:43 AM   #8
Brabs_Weather
Fan#: 93741
I woud not say you over reacted at all it is the Transfer Case Breather Tube. Lets see how it runs with water and dirty getting in the Transfer Case. As long as you setted it back you will be fine until you hit the Dealership
http://www.fordparts.com/Commerce/Pa...rd&model=Focus
2012 Ford Focus Titanium
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 09-28-2012, 09:07 AM   #9
2012silversel
2012silversel's Avatar
Fan#: 83969
What I Drive: 2014 C-Max Energi, Sterling Gray
Points 1,963, Level 26
Points: 1,963, Level: 26 Points: 1,963, Level: 26 Points: 1,963, Level: 26
Level Up 63% Completed
FF Reputation: 1 2012silversel Good Standing Member
Seriously, you're going to ignore the advice to have the dealership check this issue from the one person who has the most knowledge and wait to take the car in to have this checked out based on advice from anonymous people, I hope your oil change is this weekend. A lot of useful information is shared on this forum, but I have to say waiting is not good advice on this one. If a Ford mechanic had posted and said that tube is this and does this and it should be OK to wait, then maybe... Aren't you worried that contaminates may have entered or you may have lost fluid? With all the complaints about the DCT posted here, are you willing to take that chance? One, two or more small stones or the loss of fluid could be damaging the transmission and it's easier to address now than after. The car may be driving and shifting fine for now and I hope fine for now isn't the last thing said before failure. Best of luck.
2012silversel is offline
Old 09-28-2012, 04:01 PM   #10
xwhit3devilx
Fan#: 86578
I missed the post from the Ford tech, I must have been writing my response as it was being posted. I'll make an appointment asap.I must seem like an idiot now
Edit: Whoops, guess I did just totally miss the post. Shame on me.
